Newbie A4 Cabrio thread, Pic Heavy
VagCabby Apr 15, 2012
  1. VagCabby
    VagCabby Active Member
    540
    79
    Hello, im jamie this is my first audi which I replaced my celica 190 with due to the celica having engine problems which is now on the bay.
    I have a A4 2.5TDI Cabrio sport on an 04 plate, owned for a month. Its had a new clutch new brakes all round and 4 new continentail tyres fitted just before I bought it! there were afew things I wanted to sort on the car which were
    Paint work( im obsessed with car car being shiny and removing swirls) car paint was quite dull
    fix the broken glove box
    fix the boot storage box
    Pics of the car when I first bought it
    So first thing was to give it a detail, heres the photos
    Sun went down so the photos dont do it justice and they were taken on my phone so quality isnt the best :(
    I then went and orderd some led numberplate bulbs and side lights to smarted it up abit, supprised they gave no bulb out warning on the dash!
    white LED numberplate lights
    SMD side lights, look very blue in the photo but their not that bad, about the same as 6000k hids
  2. VagCabby
    540
    79
    Then was to fix my glove box
    I set to repair it as cheap as possible as didnt want to buy a new gloe box from audi for £100+! so I drillied 3 holes through the two broken sections of the hinge and then cut the heads of some nails and then slid the nails through the two parts of the hinge and glued in place! and removed the piston from the hinge. Door opened fine but the glove box light did'nt come on as the swich for that was fitted into the piston :doh: so here is how I got around that...
    I went to Maplin and bought a push to brake swich.
    Then removed the entire glove box from the car, only 4 bolt held it in which I was pleased about! when I got the box out I noticed this..
    There was a blanking plate for another glove box light, so i though ah I have loads of Audi interior lights sitting in the garage waiting to be fitted for my lighting pack. so i popped the blanking plate out, so I was left with this.....
    I then checked to see if my spare light would fit, which it did!
    So I set about doing the wireing (turned from fitting a swich to addign a new light and fitting a swich :lol: )so I got a OEM plug a lead from my box of cables I have lying around :cool:
    I then opened up the connector for the origional light and solderd the new cable and plug into that and then wrapped the cable in loom tape to keep it looking factory(although you cant see it when fitted :lol: )
    Light all wired in
    After that I set about sorting the swich, here is the hinge where the piston was fitted and the cable for the swich
    And this is where I was relocating the swich to, its where their used to be a litted rubber stopper at the top of the glove box
    I drilled this out to the size of the swich and fitted the swich
    I then set to work on wireing it up, I moved the plug for the original swich the top of the box, I then solderd another OEM plug and cable onto the new swich and wrapped in loom tape and plugged into the origional swich plug
    and here is the finished result
    Although its only a standerd feature in a car im well chuffed with it, took me about an hour to do but its nice having a glove box that opens and closes properly
    Then I wanted to sort out my gearstick surround, it had loads of scratches on it from where somebody was change sliding about on it, so i went onto ebay and bought some carbon vinyl and set to work,
    im very happy with the results!
  3. VagCabby
    540
    79
    The the last thing I did was fix the boot compartment, the handle to raise the boot compartment did nothing so it was just left in the down position, so I stripped all the boot lining out and found that the cables were very slack, it looked like somebody had tried to raise to box with the roof down and snapped the cable holders/stopper which resulted in the who cabled being pulled through into the gearing! so what I did was pull the cable out so it was tight and then cable tied onto the chassis, suprisingly this worked and the box raises and lowers but the hadle as it should do now! well happy as it cost me nothing and its all hidden by the boot lining.
    Close
    Pull the lever around at the top when the roof is up and gives you more boot space :cool:
    ROB A4 CAB and Sandra like this.
  4. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    28,013
    11,151
    ​Car looks amazing, what a great write up. Thanks for sharing with us. :)
  5. VagCabby
    540
    79
    Thanks Sandra, it deffo doesnt show its 130k miles which made me belive that the previous owner wasnt lieing that it had only been used on motorways!
    Anyway today had a little carbon wrap left over so I did my rear ash tray aswell, looks ok but the rear ashtray is textured so it doesnt give as smooth a finish, but looks alright :)
    Before
    After
  6. VagCabby
    540
    79
    Been busy today, took a trip to the breakers again today to see what Audi's they had down their. I wanted to find an Audi with the lighting pack installed so I could get the genuine Audi door looms for the puddle lights and red door open warning light. After searching all the cars I had no joy untill I found a 2001 Audi A6 hidden away right at the back of the yard, pulled the door card off and hay presto, it had the full door lighting pack including inside soor handle ambient lighting!!!! so that behind the door handles glows Red at night when the lights are on. Unfortunatly I will have to cut a slit into the top of the inner door handle surround to fit these which I can't do untill I get my demel in 2 days. Anyway took the door cards off, fitted the lights (holes were already their so i just had to pop them in) wired them up to the door loom so its as it would have been from factory and they work as they should :cool:
    When the door catch is in the closed position the lights are off
    When the door is opened they come on!
    Heres some bad photos of it tonight in the dark, really bad quality from my phone at night!
    I also changed the colour of my glove box lights to red which my brother in law suggested i did. Think it makes it look amazing! fits in well :)
    I began with the footwell lights after doing the puddle and warning lights, I dont have a VAG-COM so i couldnt do it the proper way by wiring them into the convenience module under the passenger seat and then reprogamming it with VAG-COM to work. Instead I wired them into the interior light and made up my own loom, I have no photos of the progress of it and it was ******* with rain while I was doing it so I was rushing :lol: But anyway they work as they should, fade on when the car is unlock and then fade off when you start the car, well happy with them although id like to fit some LED bulbs into them to give a brighter light but there ok for now. heres some photos, again they dont come out too well on my phone!
    I also set to work on the internal door handle ambient lighting, again no progress of this as it was raining but theres some photos, again need some brigher LEDs as in my partners A3 they shine abit brighter than mine, just their only supposed to be suttle and not mega bright.
    Drivers
    Passenger
    I also did abit more cleaning, The exhaust pipes were coverd in soot and rust so I cleaned these off
    Before
    After
    lastly I hated the fact my door hinges were coverd in 8 years of dirt and gime, I tried to clean them when washing the car but no joy, it was so ground in that it wouldnt come off easy so I bought some engine degreasent which did the job!
    Before
    after
  7. ROB A4 CAB
    ROB A4 CAB New Member
    21
    hello VAGCABBY nice car ive got the same problem with my rise and fall box in the boot. Is it a big job to repair as in time do i need a manual to consult as regards stripping out the boot and gaining access to the box workings thanx for any advice (rob) midlands.
  8. VagCabby
    540
    79
    Hi there, thanks
    It's pretty simple to do, remove the handle which is held with 3 or 4 torque screws and the pull out the boot lining, I think its oly cipped in from memory, then find the slack cable and pull it tight and cable tie it benhind there the boot trim goes and it should work again, sometimes the problem is a broken clip on the actual handle so check that first.
  9. EEZ_4503
    EEZ_4503 Member
    57
    20
    Very tidy car, and nice mods done so far
  10. VagCabby
    540
    79
    This has changed quite a bit since I crated this thread so here it goes from another forum
    After afew issues the cruise control is all fitted and working, I was getting all sorts of error after installing the new module, cleared all the codes and still got issues, managed to recode the whole thing and half my errors went but still had an abs warning, took it for a drive to see if it would out out but it didn't, all my warning popped back up on the bash and the car cut into limp mode over 20mph!!! Found out eventually I hadn't reset my steering angle sensor corrently which was causing all the problems, reset the steering angle sensor and all my error went and the cruise control worked!
    Well its fitted! was a pain in the **** but i got there in the end :lol: had to fabricate my own windscreen mount due to this being from a new shape A4, wiring was abit of a pig but it all works as it should now :D also fitted LEDs into my spot lights and sun visor lights to match with my footwell lighting will get a night photo soon.
    Before
    After
    I tell you its a gods end at night, absolutely love it! no more getting blinded by fogs and Hids :lol:
    Anyway completed it today and im am very happy with the outcome, has transformed the inside of the car completely and the sound quality is so much better than my concert radio. All went smoothly, needed to trim afew parts due to all my ceter consol being designed around a single din and also the climate unit needed 2 mm cut of both ends but it all fits together as it should :thumbsup:
    anyway afew photos, not many as it was getting cold and wanted to finish it :lolz:
    Double din cage in.
    RNS-E in
    So happy with it :D cant use the sat nav unti i get a disc for it :doh:
  11. VagCabby
    540
    79
    Thanks mate.
    Heres photos as promised
    And the photos of the grills
    After
    Fitted to the car
    Just a little update, been wanting to do this since i got the car, bought myself some exhaust tips cheap. Cut my pipes and cut the valance and the badly welded the tips on :lol: my welder is very old and doesnt give a good constant feed so its bloody hard to use! But there on there and there not going to fall off any time soon :D Im happy with the result, look very OEM and give the rear end abit of a boost in looks. Valance is going to be pained gloss grey tonight
    Finished
    Well i painted up the rear diffuser thing last night and laqured it this morning and i am more than impressed with the outcome, pics don't really do it justice
    Fitted
  12. VagCabby
    540
    79
    hello, just a quick update. Been wanting to change my rear lights to the later b7 cabriolet lights for ages but they very rarely come up on eBay at a good price and if they do I always get outbid at the last min. This came up at £30 buy it now, so I grabbed it. Just need to wait for a driver's side one, I don't mind paying more for the second one as I got this one so cheap. Trial fitted it to see how it looks and to work out how I'm going to wiring them in. Here's some pics
    New one on the left
    Managed to take a day time photo of the rear to show the lights! and also managed to fit the splitter in about 15 mins, was surprised how easy it was as I struggled when fitting the ménage splitter to my SI lol
    Here's some pics
    I well happy with it. I need to get hold of a RS4 rear diffuser thingy to replace my derv modified rear valance. The car is now begging to be lowered though, I think the splitter will look 10x better being closer to the ground so on the look out for some coilys or just some springs that will drop it a good amount.
    oh an she hit 150k yesterday! :halo:
    Hello, after a 300 mile round trip on saturday I now have my wheel and im sooo happy with them, look spot on onthe car and I dont even feel the car needs to be lowered (altho
    ugh I proberly still will drop it another 20mm...) anyway short and sweet
    Genuine 18" a4 sline wheels (rs6 style) 4x pirelli tyres at 245/40/18
    Heres some quick pics after a quick wash, I have since waxed the car and polished and sealed the wheels, will get better pics soon
  13. VagCabby
    540
    79
    No updates im afraid, just afew pics of the car looking its best after a cleaning session outside the caterham dealer!
  14. VagCabby
    540
    79
    Hello, i have not put an update on here for ages and nothing has changed lol
    Nothing exciting but i've done a complete front suspension refresh to the car. I half of this about a year ago with cheap arms and they gave up within a year so i have bought Meyle HD control arm which have a 4 year warranty and are highly recommended by all the Audi forums but they were not cheap! I have also bought A4 B5 suspension perches which the springs rest on which lowers the front another 10-15mm along with Gen Audi shocks and Lemforder inner track rods.
    Piccies
    Control arms and perches
    Contol arms and perches unpacked, 4 upper suspension arms, 4 lower suspension arms, 2x track rod ends, 2x ARB drop links. New bolts for everything
    New vs old shocks, old ones literally took 5 mins to rebound to upper most position
    B5 perch on shock vs slandered B6 perch
    http://s156.photobucket.com/user/ja... Uploads/20140411_114935_zpsepnarbfx.jpg.html
    Car finished, happy now the front sits lower than the back unlike before (didn't get a before pic but got loads of photos on here of it before lol)
    Car feels 100x better due to everything else being on there from new and the cars on 167k! hopefully wont need to change any of this again, took about 12 hours due to seized pinch bolts holding the top arms to the hub
  15. VagCabby
    540
    79
    All fitted. Had one issue with the loom being too short but managed to extend that to fit it. Modernises the interior and feels a lot nicer to hold.
    Before
    After
    Brennan likes this.
  16. Brennan
    Brennan Former Audi Driver Team Estoril
    2,746
    1,266
    Looks fantastic mate
  17. b16 will
    b16 will Member
    161
    13
    Following your thread :)
    Your doing all the bits I'm looking to do, as I also have a v6 tdi cab. I want to lower mine as I alredy have 18s, and twin tail pipes are comeing !!
