newbie 94 coupe wont start
lloyd lkautos Mar 17, 2008
  1. lloyd lkautos
    lloyd lkautos New Member
    im interest in what happened to mike myres problem and what was end result i have no spark at the main coil lead new coil and module fitted fuel getting through just dont know what else any help thanks
  2. scotty33
    scotty33 Member
    155
    Which engine do you have? Checking the ECU for fault codes should point you in the right direction if it is a component that has failed.
    I would try testing the hall sender if you can't get the codes checked?
  3. lloyd lkautos
    big thanks for reply its the ACE engine a friend has said change the hall sensor as everything else checks out will let you thanks
