New wheels - what tyres should i get.
Jonse May 31, 2013
  1. Jonse
    Jonse Active Member
    446
    49
    Hi Guys
    just picked up my new wheels today :) BBS CH
    [​IMG][/URL]
    They are staggered with 8J front and 9J rears. Im currently running on standard suspension but with the plan to go to HR lower springs next year.
    What tyres do you recommend? The company suggest 225/40/18 all round.
    I was thinking 225/40/18 on the front and 245/35/40 on the back.
    Any advice would be great :)
    Ryan
  2. Persian
    Persian CEO Audi S3
    270
    21
    225/40 is perfect on 8J but on the rear I think 245 would have clearance issues considering they are 9J! I guess back needs to be down on 225 also.
  3. AdriansS3
    AdriansS3 Member
    77
    I would also suggest 225 due to clearance problems.
    What offsets are the wheels?
    I was looking at the BBS vz but was concerned about clearance issues as they are 8j et 44 and my S3 is lowered about 25mm and I don't really want any rubbing!
  4. Jonse
    Jonse Active Member
    446
    49
    the ET is front 8J ET45 backs 9J ET42. So we saying 225.?
    Would that be alot of stretch, i dont want to lose that much grip.
  5. AdriansS3
    AdriansS3 Member
    77
    They would be stretched but if you fit anything bigger you will get quite bad rubbing.
    I think I will get rubbing with 8j et44 and yours will sit another 14mm further out!
  6. Jonse
    Jonse Active Member
    446
    49
    Wow how do you work out how much further it sits out then standard.
    Dont know alot about ET.
  7. Persian
    Persian CEO Audi S3
    270
    21
    Here you go mate
    http://www.1010tires.com/Tools/Wheel-Offset-Calculator
    Just plug in standard wheel width and ET (7.5J ET54) and your preferred or new wheel size and it will work out it out for you.
    ET is just about how much further the wheel sits from the hub to the arch in other words A3's standard is ET54 and the maximum which most go for is ET45+. I Personally am on 8J ET43 with 225/40.
    Hope I ain't off topic :) and helped
  8. Jonse
    Jonse Active Member
    446
    49
    Wow im not sure if i know how to use it but it shows my rear wheels will stick out my 31mm thats sounds like it will stick out loads :( i was hoping for flush
  9. S3Alex
    10,575
    4,644
    245s on the rear is doable but you'll need a fair amount of camber to avoid rubbing.
    At the front it's a different matter and we had a serious amount of work getting 245s under there.
  10. Jonse
    Jonse Active Member
    446
    49
    oh ok. Im looking to get some tyres today. Is it best to go for 225 all round then? or 225 on the rear and 215 on the front?
  11. S3Alex
    10,575
    4,644
    Its best to have the same tyre size all round.
    225s should fit under the arches as mine was on 225x40x18s from stock but that assumes the offset of your rims is correct.
    I know nothing about offsets but I do know that with everything very carefully worked out on mine that we had to go to adjustable topmounts to get sufficient front camber to get the 245s fitted.
    Not a cheap option.
  12. coreythorny
    coreythorny Active Member
    458
    74
    This, not forgetting if you run Quattro you need to ensure rolling diameter is within a stupidly fine tolerance.
  13. S3Alex
    10,575
    4,644
    Absolutely.
    Like all things Quattro and then check camber etc regularly.
  14. MartayMcFly
    MartayMcFly Booooooost Regional Rep VCDS Map User Gold Supporter
    2,749
    352
    You won't. I had 8.5" wide 19s at ET 44 with 225/35 and no rubbing.
  15. andrecc
    andrecc Member
    253
    225/35 will be fine, I'm on eibach sportline springs and running front and rear on 9J's front is 215/35 with spacer to give clearance, and rears on 225/35
  16. Veedubnoodle
    Veedubnoodle Active Member
    223
    65
    Lovely wheels mate.....I agree with everyone and reckon a 225/40 will work perfectly on them.
    Could you do me favour though.....post some pics up of the 9j rears please.
    Thinking of buying some CH's later this year and I want to see how much concave there is on them.
