New wheels rubbing on rear arch
Lukebry88 Mar 3, 2013
  1. Lukebry88
    Lukebry88 New Member
    23
    Hi just put a set of 18x8 et 45 rs4 reps on my a3 tdi 2.0 2006 and they are rubbing on the rear arch on the outside of the tyre I've got 235/40 on there and the suspension is standard.
  2. chazd
    chazd Active Member
    491
    72
    Need 225/40
  3. Lukebry88
    23
    They told me in the tyre place to put 235 on them
  4. Rom
    Rom Member VCDS Map User
    443
    Then go back and say, thanks for your advice, they rub, can i has 225 now please :)
    Think most people run 225 tops, which is standard 17" width for the sport.
    Theres a arch liner screw you can remove which a lot of people do when lowered etc.
  5. A3Kent
    A3Kent Well-Known Member Team Daytona Audi A3 S-line owners group TDi
    1,570
    249
    8J's will rub. Standard fit is 7.5J
  6. Rom
    443
    You mean 8j with 235 will, 7.5j with 235 wont ?
  7. Lukebry88
    23
    ye read about this ill give it try
  8. Eftwyrd
    Eftwyrd Member
    57
    14
    As others say, narrower tyres, remove screw or add more camber. They are your options.
  9. DOHxP
    DOHxP New Member
    20
    no point adding camber
    just get 225/40
    standard r32 wheels that are 7.5j have 225/40 on them iirc
  10. Lukebry88
    23
    Ok 225 it is then
  11. Beagles
    Beagles Member
    88
    Did you solve this? I have the same wheels but my a3 is lowered by about 40-50 mm. And it scrubs. Took the screw out and it's alot better but still does over bumps and if I had a full tank or 3-4 people in the car!:( thinking of having the insides of my wheels Lazor trimmed apparently? A friends dad I know does it? Any ideas? Only a couple of mm?
  12. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    So basically raising the ET of the alloy? Thus bringing the wheel back into the arch.
  13. Lukebry88
    23
    ive taken the screw out an it seems to have worked but I will be putting 225 on the next time I change the tyres.
  14. Burkin
    Burkin Member
    176
  15. Beagles
    Beagles Member
    88
    What's the ET? Sorry if I'm being simple here! I'm clueless with wheels and widths and offsets and all that! But basically yes. Wheel would go in a few mm or how ever much I request apparently? I've got 225 on mine now and I'm not crazy low! Think the back is fully down but tyres aren't up in the arch! Don't wanna raise it either:(
    Also, since I've put these rs4 wheels on, obviously the width and how far they stick out is different, but the car seems to wallow a little and I'm not sure if the cheapy budget tyres are causing this? Or the change in position of the wheels compared to the last ones! Any ideas?
    Appreciate all the replies guys! :)
  16. Rom
    443
    Et is offset, same thing. Higher the number, further in the arch the wheel sits.
    All the info we need is stamped on the back of the wheels.
    Something like 8j et45.
    What size tyres are you using, all numbers. Like 225/35/19.
    I'm on eibach sportlines, so 50/40mm on sport shocks. I have 8.5 wide wheels in front, et 45, with 225/35/19 tyres.
    Rears are 9.5 wide, et45, 225/35/19 tyres.
    So my rears are pretty wide, with arch screw out, I get minimal rubbing. Only if I hit a dip fast, normal driving, commuting is fine. Fronts don't rub at all.
    With exact details we can may be help more.
  17. Graham89
    Graham89 Derv Perv
    310
    I'm running 8J on 225 tyres. No rubbage at all. Even 5's up. Standard sport suspension.
