New wheels rota grid drifts?
190sline Oct 30, 2013
  1. 190sline
    190sline Member
    53
    Hey guys looking at getting some new wheels this week really fancy rota grid drifts. I want to check that the sizes I have here will fit my b6 Quattro so the wheels are 18x9.5 et20 looking at having some stretch in the form of 225/40/18 tyres will the offset be ok and the wheels not to wide to hit the top arms?
  2. Andie0
    Andie0 Member
    490
    13
    Pretty sure the et will be incorrect. You should be sticking between 35-45
  3. deano1978
    deano1978 different gear
    713
    81
    Yeah man 20et will stick out loads.
    Mine r et30 and only just tuck under lip. And they do rub.
  4. J Eyo
    J Eyo Polo GTI (6) R
    220
    Rotas fitted perfectly, (5x100, 9.5 et38) 15mm spacer at front and 20mm at back. For those who want to know, the back definitely needed a spacer, hit top of the coil mount without! could probably get away with a 5mm at the back if you weren't running 9.5 with a 15mm at the front. Had to go 20mm rear for look and handling characteristics. The clearance between the inner rim protector and the strut in the front however is roughly 2-3mm so JUST fits. Tires are stretched 225 and managed to keep the tread in the arch (rears fine, front just), can definitely lower the car in the rear with no problems, may need to roll arches or camber to the get the fronts nicely inside. One thing to note, these are LOUD rims, the thick flat wall of each spoke gives a very audible propeller like tone, and the spacers create a frequency at around 80kmh that begins to ring and never lets off as speed increases. So, if you're willing to loose a bit of that soundless s3 interior for that wiiiide super phat look, then its well worth it!
  5. deano1978
    713
    81
    PICTURES?
  6. Gazwould
    Gazwould Well-Known Member
    5,684
    2,310
    Awesome wheels usually reserved for Jap drift cars.
  7. DieselJake
    DieselJake Well-Known Member
    2,942
    751
    Yeah, each to there own but would only put them on Jap cars personally. Then again saw a nice b5 with them the other day so who knows it might work maybe it just depends on suspension setup and wheel/car colour.
  8. J Eyo
    220
    reviving an old thread here! Sorry didn't see you guys wanted me to post pics!! will do, when i'm up :p still in bed right now :D however, I'm looking at lowering now, coil overs of course, buuut will the damn things fit?? I've only got 2-3mm of clearance up front (on the inside) anyone met with similar issues?
  9. 190sline
    190sline Member
    53
    Pics pics pics :)
  10. J Eyo
    220
  11. DieselJake
    2,942
    751
  12. J Eyo
    220
    Nope s3 225 bam motor
  13. 666markyboy
    666markyboy Well-Known Member
    1,240
    60
    Those sizes are for an 8L S3 not a B6 A4
  14. DieselJake
    2,942
    751
    Sorry thought you were OP, was thinking why the heck has he gone through all this and posted up the wrong car haha.
  15. Jamiej
    Jamiej New Member
    barkclark likes this.
  16. 190sline
    190sline Member
    53
    That looks spot on! Is there much concave with them being 8.5?
  17. Jamiej
    Jamiej New Member
    Cheers. There's a slight concave but not as much as the 18 x 9.5.
