New wheels fitted and it looks crazy (IMO) PIC HEAVY
dpbayly Feb 16, 2013
  1. dpbayly
    dpbayly Member
    391
    Well after picking my new rims up yesterday from SIXONETWO in Luton i got back to my workshop and fitted them up with new tyre then had to call it a day, this morning i met up with my brother-in-law at his workshop as i need my spacers modified to cope with the new rim width and offset that was simple took 1mm off the rears so they are now 19mm (need that 1mm to stop rubbing) then came to the fronts which actually needed more adding 3mm so they are now 18mm fortunately my brother-in-law knocked them up:
    Then the next little issue was that my extended wheel bolts were designed for OEM radius fitment and the new wheels needed 60 degree taper so he sorted that out too:
    once all this was done i was ready to fit the new wheels.....
    Last pic of the RS6 reps:
    Here is a one new one old wheel looking at this pic you would never believe there's only an inch difference, the new one looks more like 20"....
    Here's one of the reasons i wanted to upgrade my wheels in the first place, to show my brakes off:laugh:
    Here's a pic showing my caliper clearance 3mm
    Finally some stand back and admire pics.....
    Loving the concave from this angle:
    Andy_w and Az like this.
  2. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    Awsome!
  3. Mike.M
    Mike.M Well-Known Member
    2,477
    169
    Spot on
  4. krisavant
    krisavant Active Member
    449
    60
    Now they are the muts nuts!! 😎
  5. adamss24
    adamss24 Well-Known Member
    4,578
    402
    Awesome set of wheels ! Well done mate !
  6. TOTE
    TOTE Just Me
    105
    10
    Perfect match to the car,beautiful wheels :hubbahubba:
  7. DALE_AVANT
    DALE_AVANT Member Team Brilliant Black Audi A4 Audi A3 Audi Avant Owner Group TDi
    618
    21
    Nice work mate, impressive effort
  8. Steffgj
    Steffgj Member
    99
    Car porn... Looks f***ing awesome!
  9. peposhi
    peposhi Member
    44
    It looks beautiful!
  10. Lee.
    Lee. New Member
    13
  11. lgooch
    lgooch Well-Known Member VCDS Map User
    1,114
    144
    I have done a sex wee ! Great wheels
  12. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    Very very Jealous. Looks amazing.
  13. Slinepete
    Slinepete Member
    314
    Awesome well done
  14. Gt Tdi_
    Gt Tdi_ Member
    32
    very, very nice
  15. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Shockingly good, wow.
    You doing anything about the rear brakes? S4's maybe?
  16. dpbayly
    dpbayly Member
    391
    Thanks,
    Im looking into it and checking out a few options
  17. pink.teg
    pink.teg Member
    170
    Nice , makes me want to spend some of my dosh !!!
  18. Pabs
    Pabs Active Member
    650
    54
    Looks so different but soooo good
  19. dpbayly
    dpbayly Member
    391
    Thanks,
    This is exactly what my aim was to look a little different and to stand out in the crowd but hopefully tastefully
  20. dejongj
    dejongj Active Member
    165
    40
    i'm sorry, they don't do anything for me. The size, the brakes, the slight stretch in the tyres, much prefer the oem look.
  21. munchkincoupe
    munchkincoupe Member
    948
    19
    That looks amazing - well done that man :applaus:
    What's the ride quality like though?
  22. dpbayly
    dpbayly Member
    391
    No worries you always get those how dont like anything but OEM,
    Im not one of them:)
  23. dpbayly
    dpbayly Member
    391
    Thanks,
    The ride isn't actually as bad as i was expecting.
    The tyre side wall hight has only gone from 9.0cm to 7.87cm on what i was running to now so not a massive difference.
    According to this tyre calculator:
    Visual Tyre Size Calculator | Kouki Tech
  24. Az
    Az Hard slammed!
    1,023
    34
    Very nice mate! Big difference that, and big up the dolphin grey! ;)
  25. AlexGSi2000
    1,464
    199
    Which coilovers do you have?
  26. crazy88
    crazy88 Loving the anonymity
    4,939
    437
    As far as I know he doesn't. Unless he's changed it, it's apex 40mm lowering springs and b5 perches on the front. I should know...I copied him haha.
    The new wheels look amazing mate, proper mint. Love what you've done with the car.
  27. dpbayly
    dpbayly Member
    391
    crazy88's right just the springs (apex) and perches
  28. Dogtown22
    Dogtown22 Member
    251
    Nice mate, are they 18's and what's the off set of the wheels before adding spacers??
  29. dpbayly
    dpbayly Member
    391
    My new wheels are 19's 8.5" wide and ET40 offset.
    My old wheels (RS6 reps) were 18's 8"wide and ET35
    This pic shows one old wheel and one new wheel as a comparison:
  30. Dogtown22
    Dogtown22 Member
    251
    Yeah I went through all this when I fitted my fat fives, I ended up with a 30mm offset, I think I could still push them out another 5mm on the rear...
  31. dpbayly
    dpbayly Member
    391
    With my spacers fitted it makes the equivalent offsets of front 18mm spacer so ET22 and rear 19mm spacer ET21 both 8.5" rim
    Are you running any spacers with your fat fives?
  32. Dogtown22
    Dogtown22 Member
    251
    Yes mate 15mm all round so I have a 30mm offset as they are et45, bet yours stick out past the arch????
  33. dpbayly
    dpbayly Member
    391
    They do stick out only a little but i get no rubbing even with 4up and a boot full.
    I'd say you could easily go another 5mm with no issues
  34. Dogtown22
    Dogtown22 Member
    251
    I had probs with one of my wheels sticking out a little further than the other, had it put (almost) right by a garage who did the alignment, any probs like that on yours?? You start to notice it when bringing the rims level with the arch
  35. dpbayly
    dpbayly Member
    391
    I haven't had a problem with any sitting out further than the other i did my alignment my self, I do run high neg camber on my rears to prevent rubbing positive from that is the handling is improved negative is tyre ware but as im in the trade tyres are so cheap for me im not worried about it
  36. Dogtown22
    Dogtown22 Member
    251
  37. dpbayly
    dpbayly Member
    391
    Looks good.
    Here's how mine sit:
    I get no rubbing issues
  38. Dogtown22
    Dogtown22 Member
    251
    I'd take abit more off em :moa:
  39. dpbayly
    dpbayly Member
    391
    Im loving the bit of poke im running not over the top and it makes for an aggressive wide stance :cool:
  40. Dogtown22
    Dogtown22 Member
    251
    haha, its all good fella, Idealy I want the top of my rims to be dead flush with my arch, do with your lathe man after i buy some 20mm, fit them then measure how much to take off!
