New Vcds User
minibob79 Aug 17, 2014
  1. minibob79
    minibob79 New Member
    9
    So just got myself a cable from Nigel and been out for a play. The main reason for getting it is iv not long got a A3 sportback quattro and my drivers rear door electrics have given up the ghost only the speakers are working did a scan and this is what i got
    Sunday,17,August,2014,12:51:29:28529
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.2.0
    Data version: 20140212
    VIN: WAUZZZ8PX8A098329 License Plate: K99 LRA
    Mileage: 136670km-84922mi Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72 77
    VIN: WAUZZZ8PX8A098329 Mileage: 136670km/84922miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: Cannot be reached 1100
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-018-BMN.clb
    Part No SW: 03G 906 018 DN HW: 03G 906 018 DN
    Component: R4 2.0l PPD1.2 1247
    Revision: --H42--- Serial number: AUX7Z0G9FNQ01V
    Coding: 0000172
    Shop #: WSC 06314 000 00000
    VCID: 74E1AC7A17D45EBE8FF-8021
    No fault code found.
    Readiness: N/A
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AH HW: 8P0 820 043 AH
    Component: KlimavollautomatH19 0420
    Revision: 112808 Serial number: 8P0820043AH
    Shop #: WSC 00000 000 00000
    VCID: 72EDAA626DC0508E9D3-8027
    1 Fault Found:
    01334 - Door Control Module; Rear Right (J389)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 28
    Reset counter: 243
    Mileage: 133544 km
    Time Indication: 0
    Date: 2014.06.19
    Time: 08:26:42
    Freeze Frame:
    ON
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
    Component: Bordnetz-SG H54 2501
    Revision: 00H54000 Serial number: 00000007810982
    Coding: E1881F01B01410004F1600001600000000085E175C010000000000000000
    Shop #: WSC 06314 000 08192
    VCID: 458721BE0CCE9736E81-8010
    Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0100
    Coding: 00150573
    Shop #: WSC 06314
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 254
    Reset counter: 18
    Mileage: 133523 km
    Time Indication: 0
    Date: 2014.06.17
    Time: 10:07:00
    Freeze Frame:
    OFF
    Voltage: 12.70 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0004012
    VCID: 418F35AE18E6BB16D49-8014
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    1 Fault Found:
    00883 - Ignition Switch (D) Terminal S
    012 - Electrical Fault in Circuit - Intermittent
    Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 L HW: 1K0 907 951
    Component: J533__Gateway H15 0180
    Revision: H15 Serial number: 1400K07A290D26
    Coding: E9827F060006022103
    VCID: 3069606AA34C229E2B7-8065
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 243
    Mileage: 133523 km
    Time Indication: 0
    Date: 2014.06.17
    Time: 10:07:30
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Part No SW: 8P0 920 981 K HW: 8P0 920 981 K
    Component: KOMBIINSTR. VDO H20 0640
    Revision: D0H20001 Serial number: AUX7Z0G9FNQ01V
    VCID: 408930AA13ECB21EDB7-8015
    1 Fault Found:
    01176 - Key
    008 - Implausible Signal - Intermittent
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
    Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
    Component: Tuer-SG H03 0060
    Coding: 0000688
    VCID: 43833FA602FAA906C65-8016
    2 Faults Found:
    02071 - Local Databus
    00913 - Window Regulator Switch; Front Right Driver (E81)
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 J
    Component: KSG H11 0080
    Coding: 1980202002186D0985054C9FC637
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Subsystem 3 - Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    3 Faults Found:
    00849 - S-contact at Ignition/Starter Switch (D)
    01038 - Central Locking Thermal Protection
    000 - - - Intermittent
    00332 - Control Circuit for Tank Flap
    007 - Short to Ground
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
    Coding: 0000688
    VCID: 44813CBA07F4AE3EFFF-8011
    1 Fault Found:
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 195 G HW: 8P0 035 195 G
    Component: R Symphony2+ H15 0250
    Revision: 00H15000 Serial number: AUZ1Z4G9068718
    Coding: 0630201
    VCID: 3665567241280CAE71B-8063
    1 Fault Found:
    00857 - CD Changer Unit (R41)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 26
    Reset counter: 55
    Mileage: 133601 km
    Time Indication: 0
    Date: 2014.06.23
    Time: 14:35:49
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
    Component: Tuer-SG H04 0040
    Coding: 0000144
    Shop #: WSC 06314 000 1012544
    just wondering if there's anything obvious someone can see im thinking the door module needs replacing but wanted to make sure it wasn't a coding problem first
  2. hades-
    9,482
    646
    yep looks like the door module
    very easy to change and ebay should provide you with one.
