New to the forum,have a clutch question.
audivro May 1, 2008
  1. audivro
    audivro Member
    Hi,have been looking for an informative forum and have definately hit on a good one.
    Anywhoo,i have a 96 b5 1.8t that probably could do with a new clutch and have been told that a vr6 unit is a direct fit?Presuming this to be the case is it going to provide a better clamping pressure?Being a tech by trade; fitment isn't an issue but want to make sure it is do'able.
    Also on this note i have read threads that these are fitted with a dmf!!:lmfao:If this is the case is there a solid unit from the vag range that will fit?
    Many thanks in advance.
  2. Broken Byzan
    13,237
    465
    I dont believ the VR6 pressure plate will fit,and i have seen some conversion kits for various VAG models that convert to a single mass FW.
    After lots of homework, i went for a SPEC stage 3 clutch and LWFW @ 16 lbs instead of 26lb for the OE one.
  3. audivro
    audivro Member
    Thanks for the reply mate,Would that be a lightened dmf or solid fw.
  4. Broken Byzan
    13,237
    465
    Mine is a solid, with a sprung friction plate. Doesnt chatter noticably, i am sure if it were lighter it would chatter like a nudists teeth in the arctic
  5. audivro
    audivro Member
    lol,may i ask where it was from?Thanks again
  6. Broken Byzan
    13,237
    465
    Ebay, Most of my car came from there one way or another.lol
    The whole kit cost me £250/£300 imported from the US as the supplier put it down as a warrenty replacement
  7. Siena
    Siena Active Member
    2,626
    VR6 clutch WON'T fit - (who said it would??)
    VR6 clutch is 228mm, 1.8T is 240mm.
  8. audivro
    audivro Member
  9. aragorn
    18,444
    847
    the QH catalog seems to suggest the A4 1.8T has a 228mm clutch? Some V6's have 240mm and others have 228mm too?
  10. Siena
    Siena Active Member
    2,626
    All VR6 12V have 228mm clutch, including Syncro models.
    All 1.8T clutches I've fitted have been 240mm.
  11. aragorn
    18,444
    847
  12. Broken Byzan
    13,237
    465
    My old OE one was 228mm ^^^
  13. Siena
    Siena Active Member
    2,626
    Mark, your car was originally a 1.8 SE.
  14. Siena
    Siena Active Member
    2,626
    Just checked - there ARE 228 and 240mm clutches fitted to 1.8T.
    Curious.
  15. Broken Byzan
    13,237
    465
    Yeah, that clutch was from my 1.8t engine/flywheel. Before i put the stage 3 on.
    So it was a 1.8t clutch, IIRC the same as the OE 1.8se one.
    Bloody cars
