New to site andlooking for knowledge
donaldson13 Dec 9, 2013
  1. donaldson13
    donaldson13 New Member
    12
    hi am going to get my timiing belt changed soon and i was wondering if there is any other things i should get done at same time, my car is an 03 2.5tdi 180 quattro sport. i have seen on different threads saying about the thermostat being something to get changed at the same time. am jst not sure on what all need or would be a gd idea. i'd be thankful for any help given
  2. TwedA4
    TwedA4 Member
    111
    welcome to the forum mate.
    some people will change their water pumps when the belts are changed, makes sense really as if the pump goes, its off with all the belts anyway...
    RE the thermostat - might be an idea to change it too. i just changed mine on my 1.9tdi at a cost of £11 for the stat and a bottle of coolant. :)
    others will be along soon with more detailed replys. :)
    HTH
  3. Mike.M
    Mike.M Well-Known Member
    2,477
    169
    Apart from the cambelt and def the water pump, I would do a full oil service, fuel filter, air filter and check all the glowpugs are working and the battery is on form for the winter.
  4. Mike.M
    2,477
    169
    Oh..........and use genuine parts from Audi or VW TPS
  5. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Yes, do the waterpump and thermostat with good quality parts.
    If all the belts are coming off the front then it would be silly not to for the sake of an extra few quid.
    I got my cambelt kit from a seller from Germany on ebay (autosmotorcraft) which included everything and good quality parts, contitech belts.etc
  6. quattrojames
    14,050
    574
    On the 2.5 it's buried in behind the water pump so it's not such an easy job...
    For this reason, while the front is off change idler/tensioner pulley (and bolt), belts, water pump, thermostat etc - anything less is false economy. I'm now breaking my 2.5 as the previous owner saw fit to save a few quid come service time...
  7. donaldson13
    12
    Thanks for the info I think I'll add the water pump 2 my list and tensioners, was thinking ov getting belt kit from eurocarparts it's a contitech kit
