New to forum need a little advice please
ben987654321 Jul 6, 2011
  1. ben987654321
    ben987654321 New Member
    hi guys/ladies,
    bought my first s3 about a month ago....love it!!
    has a few probs:
    driver side door sometimes showing open when it is shut any ideas on the part and price?
    also dump valve has shown a fault on ecu - malfunction so needs to be replaced!.....i want to replace it with a aftermarket one BUT want to keep original sound level etc DO NOT WANT BOY RACER SOUND....any ideas?
    thanks so much for your time
    ben
  2. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    If you dont want the aftermarket sound, just get an oem divertor valve - simples :)
  3. S3MMA
    S3MMA Member
    235
    My door does that randomly... I would be interested in finding out what is causing it ..be careful it doesn't drain your battery I have had to turn my light off inside the car as it stays on if the car doesn't think the door has shut!
  4. Dane
    4,086
    182
    theres a thread some where... Ill try and find it
  5. Heisenberg
    Heisenberg Member VCDS Map User
    67
    Hi Ben welcome to the forum I'm new myself, with the dv (dump valve) issue alot of people replace with the forge 007 which is alot stonger than the original and still sounds the same (no loud blow off noise) and the door has yours dropped a bit? as that can flag up
  6. <tuffty/>
    21,576
    4,048
    The door thing is a common as muck issue to do with the switch built into the door latch... extreme fix is a new door latch but not cheap (apparently), the cheaper fix is to remove, clean, relube and replace the latch... although tends to just give you more time until it goes again...
    Mines does it more when its real hot outside...
  7. Dane
    4,086
    182
  8. S3MMA
    S3MMA Member
    235
    Yeh mine never does it first thing normally when I come out of work its proper annoying I keep opening it and trying at every set of lights grrrr
  9. markthenewt
    markthenewt Member
    250
    My door does this too but only when hot, after I have pulled off I open the door and slam it and it's goes off, not good slamming the door but it gets rid of the annoying door open sign.
  10. jcs356
    jcs356 Brum brum
    2,734
    70
    So does mine!
