New Style Rear LED Lights/ sidelight bulb replacing
gazzaw888 Mar 14, 2010
  1. gazzaw888
    gazzaw888 Member
    30
    Hi guys
    does anyone have a guide to fitting the new style rear lights or is this best left to a garage?
    would audi be the best place to shop for these?
    i have just ordered new white PIAA sidelights, does anyone have a guide or any tips on fitting these also looks fiddly :crying: ?
    fairly new to the site any help would be much appreciated
    cheers
    GARY
    audi a3 s line 2.0tDI 170
  2. robby
    robby Active Member
    576
    68
    The rear light units are a doddle to fit taking 5 mins.
    Inside the boot there is a round blanking cover behind the lights, remove this and you'll see a plastic nut (long). Remove this using a screwdriver in the slot and then pull the light unit towards you slowly from the boot side. Don't pull it too far as there are 2 metal lugs which push into the rear wings, these need gently pulling outwards until they pop out of their rubber bungs. When all are free release the wiring connectors, the new lights come complete with new bulbs and holders
    The sidelights are easy enough, remove the back covers by releasing the metal clips (push sideways), pull the dipped beam bulbs out of the way by pulling the holders straight out for a bit more room (no clips), then using a small flat blade screwdriver it's just possible to prise the sideligh holders out
  3. gazzaw888
    gazzaw888 Member
    30
    cheers Robby :salute: thanks for the help m8 my mates a mechanic so i will invite him down to supervise :slap: , can i be cheeky and ask where you got your 09 rear lights?
    also i noticed you have alloy pedals is ebay my best bet for these ? thanks again Gary
  4. HIGGINS
    HIGGINS Member
    528
    15
    do the s3 front and rear lights fit a3? 2006
  5. robby
    robby Active Member
    576
    68
    I've bought 1 light off ebay for £21 :icon_thumright: just need to order the other this week (£80+ from dealer) - i got the S3 pedals off ebay for £61, i think they're £120ish from dealers
  6. robby
    robby Active Member
    576
    68
    Not sure about fronts but the rears are the same on all A3 + S3s - newer versions are from 2008
