New steering module, ESP and power steering lights on.
MxGaza33 Jul 13, 2012
  1. MxGaza33
    MxGaza33 Member
    148
    9
    After a few problems I finally got my MFSW to work after installing a new steering ECU (8P0 953 549 F). Now it's thrown up the ESP and power steering warning lights along with having no power steering. I've had the power steering problem after changing the wheel before and it was solved by turning the wheel all the way to the left then all the way to the right, but this isn't doing it this time! I've took it for a drive to see if they would sort them self out but no luck. I've also tried disconnecting and reconnecting the battery. Is there some coding that needs to be done in Vagcom as its a new ECU?
  2. murran
    murran Well-Known Member
    1,545
    39
    if its new it'll require coding in to tell it what car its fitted to (options wise) and to initialise.
    yep, turning fully to the left then all the way to the right and back to center, not too fast and not too slowly, should then set up the power steering.
    a short straight ahead (above 12kph (at a guess?)) drive should set up the steering angle at 0 (esp light goes out).
  3. MxGaza33
    MxGaza33 Member
    148
    9
    Will I need to code it first before I can get the power steering and ESP back? Also do you have any useful links that explain how to code it properly? Thanks
  4. murran
    1,545
    39
    not really any coding i do at work is usually thru guided functions on the vas 5052.
    you could plug the old ecu into the car.... read the coding off that..... then swap in the new one..... and input it manually into the new one? but as youve got a different steering wheel its probably not the same........
    couldnt you just have got the old ecu recoded to tell it it now has the multifunction steering wheel option??
  5. mike foster
    3,967
    Only steering modules 8P0 version E and F can be coded for mfsw.
  6. Ash187
    7,444
    704
    If you have changed the steering control module then you will need to code the new module to suit your car and do a basic settings reset on your steering angle sensor and possibly on your abs module. I have had this many times when retro fitting these modules for mfsw and cruise
  7. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    As Ash mate, it is not just a case of turning wheel to reset, you need to do some basic settings with vcds. PM your email mate and I can send you a guide on how to do this.
  8. MxGaza33
    MxGaza33 Member
    148
    9
    Ah I see, I've pm'd you my email :)
  9. murran
    1,545
    39
    ah, i see.
  10. MxGaza33
    MxGaza33 Member
    148
    9
    All sorted, cheers bluequattro for your vagcom skills! :thumbsup: Power steering has never felt so good!
  11. bluequattro
    bluequattro Member VCDS Map User
    411
    You are v welcome matey :)
  12. Scholey3
    Scholey3 New Member
    24
    Hiya bud is ther any chance you could email me this guide.. Im havin the same problem, thanks
  13. jimcazz
    jimcazz jimcazz86
    Hiya m8 is ther any chance you could email me this guide as iv put new speedo in started car but loads of faults come on so put old speedo bk in and now no power steering any idear m8???
