New Software new graph from Rolling Road on the 3.2
imported_S_Line Jan 20, 2006
  1. imported_S_Line
    imported_S_Line Guest
    New Software has been installed on Clives rollers over Christmas.
    Before Christmas we had a little S3 vs A3 3.2 shoot out.
    details are on here somewhere with also a video clip.
    http://www.audi-sport.net/ubbthreads/sho...part=1&vc=1
    Now as many will know the Quattro system on the A3 is a pain to power run. So a software upgrade on Clives Rollers now produce these new results from my 3.2.
    The run was carried out in 5th. other gears were used, 5th was the best readings.
    We found that in 6th at high speed the power is shifted to the rear wheels and taken away from the front wheels, this is done automatically and may be down to handling on high speed motorways ?
    Anyway, torque is far better now and is back where Audi say it should be.
  2. TDI-line
    TDI-line Uber Post Whore Team Floret Silver quattro Audi A3 Black Edition TDi
    9,609
    1,433
    Nice one.
  3. imported_S_Line
    we are thinking the dip in the middle is down to the Cams or something changing mode ? can anyone clarify this ?
  4. Cupramax
    Cupramax Uber pimp meister
    457
    Why didn't he just remove the haldex fuse and run it 2wd? What has this software acheived as your cars supposed to produce 250hp isn't it??? /ubbthreads/images/graemlins/confused.gif
  5. god_thats_quick
    2,507
    [ QUOTE ]
    Why didn't he just remove the haldex fuse and run it 2wd? :
    [/ QUOTE ]
    Because that can bugger your haldex clutch and won't be accurate as your not driving 4 wheels as the car should be!
  6. miketweed
    miketweed Member
    371
    Cupramax, this fuse removal business, surely it will cause huge heat build up in the haldex unit? which is only designed to have minimal speed differences between front and rear drives.
    With stationary rear drive and front drive doing near on 140+mph, the multiplate clutch in all that oil will be causing some heat, as wet clutches always drag a little.
    Just a thought.....
  7. Cupramax
    457
    I would think driving 2 wheels would be more accurate not less. Only going on what I've seen done before at Stealth who are reputable...
  8. Amchlolor
    Amchlolor Active Member
    5,604
    That's a fair dip at 4000rpm.
    I'd expect any tuner to be able to fix that easily.
  9. JaminBen
    JaminBen Member
    532
    [ QUOTE ]
    [/ QUOTE ]
    Sadly, I don't think so Bowfer: all the remapped 3.2VR6s I've seen have this dip. I believe it is at that point that the variable manifold switches from long to short runners.
    What I find strange is that the graphs should read power at the wheels. So 250 + 23% (what VAG claims is lost in the MkV Haldex system) would be over 305 hp, which of course is ludicrous. Or are these graphs showing the "at the crank values?
    If so, what was the correction factor used?
    TIA,
    Ben
    PS: I've been trying to scan my plots, but I guess I'll just photo them: looks ok!
  10. JaminBen
    JaminBen Member
    532
    Nevermind, looked at the graphs again: there are numbers at the wheels and at the crank!
    Sorry for the bother.
  11. imported_S_Line
    Another thing we noticed was when we tried in 6th (DSG) the power was shifted to the rear wheels at over 110 mph. and caused some choppy going ons /ubbthreads/images/graemlins/frown.gif
    Using 5th this didnt happen.
    Seems like a stability program, that alsters more power to the rear wheels when only on 6th and at very high speed. /ubbthreads/images/graemlins/smile.gif
    Things like this you would never know when driving at high speed as it feels so sure footed anyway.
  12. cosmicblue
    cosmicblue Member
    320
    [ QUOTE ]
    [/ QUOTE ]
    DSG and Quattro are you sure? Been to the pub have you /ubbthreads/images/graemlins/cool.gif?
  13. mikep
    mikep Member
    591
    V6 Quattro DSG, that's what the sig says! It's the only model you can get the combination on at the moment.
  14. imported_S_Line
    . /ubbthreads/images/graemlins/book.gif oh well im sure your Oil Burner is fine ! /ubbthreads/images/graemlins/wink.gif
  15. johnmv55
    johnmv55 Member
    247
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    TIA,
    Ben
    [/ QUOTE ]
    All the Porsches I have run on rollers with "varioram"-- a resonant charge device, have a similar dip where the flaps or trumpets operate, holding them ON or OFF does get rid of the dip, but it also loses massive power either below or above the existing dip, thats life !!!!!!!!!!
  16. cosmicblue
    cosmicblue Member
    320
    oooer wot a tvvat I have becum
  17. JaminBen
    JaminBen Member
    532
    [ QUOTE ]
    [/ QUOTE ]
    Indeed. There's not much one can do against the laws of fluid dynamics, and the openeing/closing of flaps always creates a very slight loss of flow.
    One VR6 tuner had a turbo kit for the 3.2, in which the variable intake was made to stay in the "short runner/high-rpm" position. Approx 20lb/ft of torque were lost, so that's what the long runners are "giving" low in the revband...
  18. imported_S_Line
    I'm booked in for the All New REVO map for the 3..2
    AS REvo are updating their 3.2 maps all the time, and its down to me to test them out /ubbthreads/images/graemlins/smile.gif
    details up soon /ubbthreads/images/graemlins/wink.gif
