New shape S line steering wheel on a 2003 audi a3
Harris
I didnt say buy the proper bits for nothing. You cant make that set up work on your car....its that simple.
sorry just confused because people are saying you cant fit it and some people are saying you can but its 50/50 chance if the airbag will deploy or not.
okay so got a little update, been the garage today and got my car on the computer, i'll start with the airbag faults
Air bag faults -
024c - Driverside front airbag ignitor circuit 1 maximum exceeded
0634 - ignition circuit headbag driverside, maximum exceeded
028E - belt tensioner ignition circuit driverside, front less then minimum
04C2 - ignition circuit side airbag passenger side front maximum exceeded
esp faults -
030A - Steering wheel angle sensor mechanical fault
032A - Front axle pressure sensor basic setting not performed/ wrong
030A - Steering wheel angle sensor basic setting not performed/wrong
058F - lateral acceleration sensor basic setting not performed / wrong
This is the bottom line.
With the correct ECU and Slipring you can fit it fine and there will be no fault codes but there is a chance that your airbag may not deploy if you're ever in an accident.
If you're not bothered about the airbag deploying (which you should be) then by all means buy an ECU and Slipring and keep the wheel and it'll pass MOT's no problem but our recommendation, for obvious reasons, is to go back to your original wheel in order to know that the single stage airbag will deploy on impact.
Definitely need to change the ECU/Slipring or Revert back to the original wheel.
The fact that Drivers Ignitor 1 is only mentioned and not Ignitor 2 means that the ECU/Slipring is only looking for 1 Ignitor (Single stage airbag)
Like I said in my previous post, I'd recommend changing back to the original Single-stage airbag which will fix all of your problems and you'll probably end up in profit as you'll be able to sell the wheel and airbag you have now for ~£250 and pick up a Single Stage wheel and airbag for ~£50
Listen to what you are being advised please, running out & buying another wheel with proper airbag will help 1 thing, but wont resolve everything, you need to clear or fix the other warnings present, namely the angle sensor etc that need calibrating, once these have cleared then attack the airbag issues, they're 2 different systems, not 1 problem, but 2.
so far i need to get the original wheel, o/s curtain airbag, o/s seat belt with tensioner.
does anyone know what i will need to get to cure this?
and the steering wheel angle sensor fault wil that dissapper when the new steering wheel is fitted?
isnt basic setting something to do with cailbrating, when you turn the wheel to the left, turn to the right, drive forward etc..?
okay i'm listening, so i need to attack these ones first -
done a bit of research on the internet and found this -
VW Golf (1K) Brake Electronics (MK60) - Ross-Tech Wiki
it looks like its got the information to cailbrate all 3 of these (let me know if i'm wrong)
will it have to be done on a vagcom because my friend has a bosch diagnostics system?
030A - Steering wheel angle sensor mechanical fault - will this result in me having to get a new steering wheel angle sensor and should i get this before i do cailbration?
sorry about all the questions i just dont know much about this :sorry:
Yes try & calibrate the angle sensor etc 1st, if that still shows issue with sensor then you'd need to strip down the steering column to check the pins/connections as if someone's been messing with that area, they may have fitted it back badly & yes use VCDS, not the bosch rubbish.
so i need to find someone with a vag com to get the sensors calibrated, i have put a thread up to try and find someone near me, amar06fbr has kindly offered to help me but he does seem pretty far away in bradford, i dont suppose theirs anyone on this thread who lives a little bit closer to the west midlands with a vag com and could kindly help? if worst comes to worse i will just drive 100 miles to bradford.
i've found someone thats in cheshire and is willing to help, so fingers crossed might be able to get these sensors calibrated pretty soon.
im gona be at tamworth saturday around 7pm
bez tamworth is pretty close and i'm free saturday night aswell, so might have to take you up on that offer, pm me your number
Just got back from meeting bez in tamworth, gotta say what a real nice helpful guy! we've managed to calibrate evrythin and now the esp light is off but now my steering has gone really heavy, like my powersteering pump has stopped, it was pretty dangerous on the drive back, next step I think is to get the new steering wheel.
Thats part of the calibration, when you do these, sometimes you have to do the steering angle sensor again as it can reset it & steering becomes hard, but in most cases a drive down the road should clear this, if not then needs another vcds calibration doing.
i did the angle sensor 2 times it just would not let me do the Steering Limit Stop Adaptation i tried 5 6 times just wouldnt have it<br><br>codes below&nbsp; im back down his way weekend last night i was really busy had a daft meal had to sort so couldnt have any longer on it <br>i had to do my a3 angle sensor then the steering limit stop a few days ago and that did it 1st try i dont think the steeringwheel bag has had the wireing modded
VCDS codes for the a3
5,February,2012,19:24:25:27402
VCDS Version: Release 11.11.2 (x64)
Data version: 20120126
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: WAUZZZ8P44A028058 Mileage: 112680km/70016miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5334
Revision: 12345678 Serial number: AUX7Z0C5FN60KR
Coding: 0000072
Shop #: WSC 06435 000 00000
VCID: 2756117796F635B
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0055942
VCID: 336EF527522E49B
2 Faults Found:
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
01423 - Lateral Acceleration Sensor (G200)
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 A HW: 8P0 820 043 A
Component: KlimavollautomatH11 0120
Shop #: WSC 00000 000 00000
VCID: 2A50E84385E4083
6 Faults Found:
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 214
Mileage: 107532 km
Time Indication: 0
Date: 2010.10.14
Time: 00:00:53
Freeze Frame:
Temperature: 19.0°C
Voltage: 11.90 V
RPM: 0 /min
Load: 0.0 %
Load: 9.0 %
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 147
Mileage: 111965 km
Time Indication: 0
Date: 2012.01.05
Time: 19:59:58
Freeze Frame:
Voltage: 7.90 V
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 118
Reset counter: 162
Mileage: 100850 km
Time Indication: 0
Date: 2010.01.15
Time: 10:21:46
Freeze Frame:
Temperature: 15.0°C
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 111
Mileage: 112078 km
Time Indication: 0
Date: 2012.01.02
Time: 00:01:18
Freeze Frame:
Temperature: 4.5°C
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 55
Reset counter: 123
Mileage: 109613 km
Time Indication: 0
Date: 2011.12.17
Time: 13:31:21
Freeze Frame:
Temperature: 8.5°C
01856 - Temperature Sensor for Heated Seat; Right Front (G345)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 111
Mileage: 112078 km
Time Indication: 0
Date: 2012.01.02
Time: 00:01:18
Freeze Frame:
Temperature: 4.5°C
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H27 0401
Revision: 00000000 Serial number: 00000006584392
Coding: 018ACF00A2141000000000000000000000
VCID: 3B7EDD077A7E81B
Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0180
Coding: 14352400
Shop #: WSC 00000
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0011602
VCID: 458ABBFF0CBAC7B
4 Faults Found:
00588 - Airbag Igniter; Driver Side (N95)
001 - Upper Limit Exceeded - MIL ON
01588 - Igniter for Head-Airbag; Drivers Side (N251)
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
002 - Lower Limit Exceeded - MIL ON
01218 - Side Airbag Igniter; Passenger Side (N200)
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 007 0030
Coding: 0000012
VCID: 3064FA2BA338723
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 D HW: 8P0 920 980 D
Component: KOMBIINSTR. VDO H25 0070
Revision: D04 Serial number: 2245CD04000850
Coding: 0004403
Shop #: WSC 00415 210 57172
VCID: 3874C20B4B48AA3
1 Fault Found:
01298 - Instrument Cluster Lamp Test
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 138
Mileage: 111232 km
Time Indication: 0
Date: 2012.01.02
Time: 00:01:23
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0070
Revision: 08 Serial number: 17001035275030
Coding: 3D0F0B40070101
VCID: 26481C7391FC2C3
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D04 Serial number: AUX7Z0C5FN60KR
Shop #: WSC 00415 210 81338
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H09 0010
Coding: 0000048
VCID: 3972C70F7042B3B
1 Fault Found:
01340 - Mirror Adjustment Switch
008 - Implausible Signal
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 143 K
Component: EPS_ZFLS Kl.7 0308
VCID: 3260F023AD34403
1 Fault Found:
02546 - Steering Limit Stop
Freeze Frame:
Mileage: 2680 km
Temperature: 36.0°C
Voltage: 14.00 V
Voltage: 13.90 V
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0030
Coding: 008800186D288505485AC63000
Shop #: WSC 00046 046 52295
VCID: F9F2870FB0C2F3B
Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Part No: 1K0 907 719
Component: Neigungssensor 002 0002
Part No: 8P0 951 177
Component: Innenraumueberw.H01 0010
2 Faults Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication - Intermittent
000 - -
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000048
VCID: 3A70D8037544B83
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 HW: 8P0 035 186
Component: concert II EU H51 0060
Revision: 05S Serial number: AUZ2Z3C1057706
Coding: 0001001
VCID: EFE6B957FE86ADB
5 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 242
Mileage: 137450 km
Time Indication: 0
Date: 2009.10.01
Time: 00:15:58
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 4
Reset counter: 151
Freeze Frame:
Bin. Bits: 10
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 151
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 137452 km
Time Indication: 0
Date: 2009.10.01
Time: 01:14:27
Freeze Frame:
Bin. Bits: 10
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 19
Reset counter: 139
Mileage: 108836 km
Time Indication: 0
Date: 2010.12.10
Time: 18:55:09
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 A HW: 1K0 963 235 A
Component: PTC-Element 0303
Revision: 00400000 Serial number:
VCID: 2952174F80E203B
End ---------------------------------------------------------------------
I've also got a problem with my central locking, everytime I lock the car, the alarm goes off and the only way I can stoip the alarm is by opening and closing the passenger door and then it will lock. Does any of these fault codes look like the suspect?
Are those codes after your calibrations Bez?
If after then tbh mate there's a fair few faults there, needs properly looking at & checking through 1 by 1.
NHN yes after
theres quite a few to get through
as i said i just didnt have more time its had a side crash if i rember right clocks plastic is cracked so i thing they have replaced the dash or it was hit hard but iv told him get a wheel and ill refit and have a good look through the codes
Yeah tbh its only thing you can do, go through 1 by 1.
its gona cost
Yeap exactly, that list of faults, wont be a quick fix.
I worked on a fellow forum members car with the 00778 Steering Angle sensor fault and Stop Limit fault.
Tried to calibrate but wouldnt calibrate properly so went about replacing the Slip Ring and calibrated and worked fine. Could be the same here?
Regardless of the steering wheel being the wrong one the Steering Angle sensor fault shouldnt be there.
Like said above, not gonna be an easy task.. I'd love to get my hands on it haha.
i also think its the slip ring
after the crash it was fully bodged
oh while your here how much for cruise cowl and dis stalk posted ?
that will do me
bank transfer ?
You & me both, its a challenge car lol
Yeap as I mentioned further up, wheel & steering angle are independent, so need to deal with seperately, but after what Bez has said, god knows what they've done to the car, just hope it was dirt cheap.
You need someone to spend time on the car to look at fixing the issues, no other way.
been today to collect a few bits for the car, 2004 3 spoke audi steering wheel, including air bag and all of the steering column, air bag module, passenger and drivers seat belt tensioners, drivers and passengers curtain roof airbags (only drivers is needed) and a dash board that i didnt need but the guy gave me.
hopefully after getting these fitted and a little help off bez and his vagcom, we can clear a few of the faults
i dont mind codeing them up ill even go as far as fitting the wheel slipring etc
but you will have to sort the roof bags module and seatbelt bits
i just wont have time to fit the rest
ill be passing tamworth as every week but i aint got hours as i head to south wales to see my missus and kid on the weekends
no problem bez, i'll get everything fitted first apart from the steering wheel and column, thanks for your help
you want the column fitting ?
no just the wheel and slip ring, i just said that because the column is connected to the wheel at the moment
