New S3 rims on and Old S3 + PCD adaptor
northern monkey Oct 5, 2010
  1. northern monkey
    northern monkey Member
    40
    Can anyone tell me if a new S3 rim with a PCD adaptor to change from 5x100 to 5x112 will fit on an old S3. Also does anyone know if you can buy 8l S3 discs in 5x112?
    Graeme
  2. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,297
    373
    do you know what size the new s3 rims are? diameter, width and offset? and what spacing will the adaptor give you?
  3. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    You will need 5x112 to 5x100 adapters to fit new S3 alloys onto the old S3's. You can't buy 8L S3 discs in 5x112.
  4. northern monkey
    40
    Thanks for the replies guys. The rims are ET44 offset 225/35/19" x8" what adapter do you think I can use?
  5. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Give Style Dynamics a call, they're good friends of mine! They've been into the wheel scene for years now and are also Longlife exhaust dealers.
    Tell them Troopa told you to call and they'll help you out with any wheel questions you have! 0208 561 0001. They're still open now.
  6. Alex C
    3,297
    373
    well i think adaptors are typically 20mm thick droping your ET down to 24, which with 8" wide rims should be fine. I run 8.5" rims with ET25 and there fine
  7. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    i run 9's with et12 on the rear :moa:
  8. northern monkey
    40
    Do any of you helpful guys have anywhere you'd recommend where to buy good quality adaptors from?
    g
  9. Alex C
    3,297
    373
    maybe i'll have to get some spacers :)
    8" ET10 with 10mm spacer up front Kev?
  10. Alex C
    3,297
    373
  11. s3_kev
    2,002
    23
    im running et27 up front on 9" so most your be able to squeeze would be et15 on 8" i reckon i run stretched tyres too for clearance, an et10 wheel with 10mm spacer would leave you with et0, that would clear the rears id imagen, when talking these tight lines though camber and tyres come into equation
  12. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    Will all this playing to a massive extent not cock up the feel of the car?
    I fitted 8" with et13 on my mk2 golf which is quite a way from the standard set up and it feels alot diffrent. Not in a 100% good way. it pulls around with the surface of the road and tram lines alot.
    That said as its a mainly track/ weekend blast car its more about the good feel when pushed hard into a corner.
  13. LD3
    LD3 Member
    98
    I'm going to run 8" wide et18f et 13r hope this fits and feels ok
  14. s3_kev
    2,002
    23
    mine dosent handle to great tbh its still alot better then standard but due to having the 19's and stretched tyres its a compromise, however on 18's and maybe going 8 or 8.5 inch wheels then you could loose the stretch on the tyres and it would handle awsome, im looking for some winter wheels atm which will put me into this setup for the wet roads
  15. northern monkey
    40
    Thanks all for the advice. They fit perfectly with a 20mm adapter. I think the rears could maybe have taken a 25mm. But I'm over the moon with the result.
    Berfore:
    [​IMG][​IMG] [​IMG]
    And After:
  16. Alex C
    3,297
    373
    ah, it was your car i saw on the piccy thread, looks real good, nice one!
  17. northern monkey
    40
    Yip. It's mine. The rear was still riding a little high from being jacked up on this photo. I haven't noticed any real change in the ride quality TBH. Tyre roar on the other hand is noticeably louder. Gotta wait for the tyres to wear out now before I try the Goodyear F1's I wanted originally.
  18. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    nice one, good colour.
    Did you get them second hand?
  19. northern monkey
    40
    Yip I did. Got them of a guy on here.
  20. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    ck's are very nice!
  21. northern monkey
    40
    If they're good enough for Ferrari, they're good enough for Audi's :)
  22. Dane
    4,086
    182
    Ah I see, I wondered why you didnt just get ones with the correct stud pattern. CK's are lovely but the black ch's tickle my fancy, if only they werent £1400 odd without tyres
  23. Alex C
    3,297
    373
    did you have to get the special BBS spigot rings for them?
  24. northern monkey
    40
    I did mate. Why do you ask?
  25. Alex C
    3,297
    373
    i had a nightmare trying to get the right spigots, so in the end i ordered some BBS spigots which come as a fitting kit (centralising rings, retaining rings and new bolts for some reason) Cost about £70. Quite a lot i thought
