New S3 owner help needed
Pedrosousa Apr 19, 2011
  1. Pedrosousa
    Pedrosousa Member
    174
    Hi, I bought one S3 from 08/2000 with 155.000 km the car doesn't have fault codes, in the engine module, but I don't feel the power that I was expecting?
    What could it be?
    It smells to much to the gasoline outside the car, does anyone knows what could it be?
    I have one fault code in the AC, and it doesn't work:
    Address 08 -------------------------------------------------------
    Controller: 8L0 820 043 M
    Component: A3 KLIMAVOLLAUTOMAT_D77
    Coding: 03140
    Shop #: WSC 06435
    1 Fault Found:
    00792 - A/C Pressure Switch (F129)
    31-00 - Open or Short to Ground
  2. Westy
    Westy Well-Known Member
    17,443
    1,103
    :sign_welcome:
    If you have a strong smell of gasoline outside the car then the fuel filter might need changing. It's under the drivers side of the car.
    If you are down on power try investigating the mass air flow sensor first. These can get worse without showing any errors.
    With regards to the AC fault code, this is what the cause could be:
    Possible Symptoms
    • A/C System not working
    Possible Causes
    • A/C System Malfunctions
      • Over or insufficiently charged
      • Refrigerant System blockage
      • Insufficient Air Flow to Condensor and/or Engine Radiator
    • Wiring to/from A/C Pressure Switch (F129) faulty
    • A/C Pressure Switch (F129) faulty
    Possible Solutions
    • Check A/C System for Malfunctions
    • Check Wiring to/from A/C Pressure Switch (F129)
    • Check A/C Pressure Switch (F129)
    Hope this helps.
  3. superkarl
    superkarl MAN OF STEEL
    9,405
    2,379
    On a car of that age I'd be changing plugs, filters, maf, coilpacks anyway just for piece of mind. Don't be surprised if the turbo is tired too.
  4. Westy
    17,443
    1,103
    Yep same old story of old S3s :(
  5. superkarl
    9,405
    2,379
    Its a sad story :( they require much love nowadays.
    Maybe worth cleaning injectors too mate.
  6. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    This is always the problem with buying 100+ milers at the end of the day.... It's just the nature of the beast sadly.
  7. Westy
    17,443
    1,103
    No problem, mine's nearly running like new now ;)
  8. Welly
    10,696
    127
    After some well deserved love an attention :).
    After 100K that exactly what they need.
  9. Westy
    17,443
    1,103
    I spend more time and money on the S3 then the bird ;)
  10. Welly
    10,696
    127
    Same. And never hear the end of it..... lol.
  11. superkarl
    9,405
    2,379
    We are there life support machines lol.
  12. Pedrosousa
    Pedrosousa Member
    174
    The idea is to change that and other stuff in the car, but now I don't have time to do it...
    I think that the car it's running good today, it's a lot more cooler than last week, and now I'm using 98
    How do I do to program the door close até 15km/h?
  13. Westy
    17,443
    1,103
    You need to download a little program called "basecode" and that will work out the code you need to enter into VCDS to code it.
    Pedrosousa likes this.
  14. Westy
    17,443
    1,103
    If you PM me your email address I can send you a copy
  15. Pedrosousa
    Pedrosousa Member
    174
    Thanks I've downloaded it and it's working :D
