New S3 owner but very unhappy
patTTpoa Oct 27, 2011
  1. patTTpoa
    patTTpoa Member
    793
    Hi peeps,
    Last week I became a very happy man, I've alway wanted a S3 for as long as I can remember & now I have one.
    Its in really nice condtion with full service etc but one thing that did play on my mind was that the person I got it off only had it a few months....
    Anyway, after getting it home & down my mates garage on a ramp I find out that the 4x4 isn't working!
    We put it on VAGCOM but couldn't comm with the haldex, which reading about it on this forum could be a problem with the muti plug.
    But now that isn't really a big problem as 2 of the big end shells has spun has damaged the crank & 2 of the rods.
    which leads me to a question for you guys, which engine codes can I use as a replacement?
    My engine code is APY, could I fit a AGU engine with all the bits off of mine?
    Many thanks
    Pat
  2. doublem_1
    doublem_1 Member
    499
    Not to state the obvious but did you check the fuse? Sorry to hear about your problems :(
  3. patTTpoa
    patTTpoa Member
    793
  4. patTTpoa
    patTTpoa Member
    793
    Hi, thanks for the reply.
    Is that fuse 31? If so yes I did check that.
  5. <tuffty/>
    21,573
    4,047
    Check the earth strap too... there is a braided strap connected from the body to the rear subframe... can't remember exactly where it is but you will be able to see it looking underneath the car
  6. doublem_1
    doublem_1 Member
    499
    Not sure which fuse number, should say in the book or on the back of the trim cover. Like said, check earth strap too. Also, has it been vag com scanned?
  7. <tuffty/>
    21,573
    4,047
    Read the posts above mate, he has checked the fuse and used vagcom lol ;P
  8. MUSH
    MUSH MUSH Developments Ltd.
    713
    12
    You could fit an agu engine in place of yours. The agu lump has a different compression ratio but it does work fine. You could fit your pistons with new rings in a good agu block and it would be spot on, complete with a built in large port head conversion!
  9. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,186
    What miles is this thing on?
  10. patTTpoa
    patTTpoa Member
    793
    Thanks for the replys,
    It's coming up to 110k so still low mileage wise really, the person (kid) was a bit of a breaker as I've found out!
    Are you sure the comp is different with the AGU?
    Also what else would you say to do as the engine will be out
    Cheers, Pat
  11. superkarl
    superkarl MAN OF STEEL
    9,553
    2,453
    yes compression is slightly different, 9.5:1 compared to 9.0:1. this can be considered a good thing and possibly give some extra power when tuning (going off wellys car).
    if you can get an agu engine for a good price its well worth the swap imo, large port head, high CR, and still has 20mm wrist pins.
    have yoiu consider rebuilding yours with forged rods and new bearings etc? this would be a good basis for mods in the future if you do get carried away.
    stuff you should consider doing if it hasnt been done is, oil pump, cambelt tensioner, cambelt, water pump, head gasket.
  12. patTTpoa
    patTTpoa Member
    793
    We have thought about a rebuild, but the crank is shot, I put a new set of gen shells in & with in 8.7miles it picked up again on the crank. The AGU does sound a good way to go. Where is the best place for uprated parts? Rods etc?
    Many thanks
    Pat
  13. Dani_B19
    9,336
    391
    so is the AGU block a different compression? I thought its was the piston that altered the compression or am i getting mixed up? haha.
  14. 16Klappe
    5,795
    1,186
    Get yourself on JBS, hmmmmmmm yummy!!!
    IE Rods are what I want.
  15. Inertiauk
    Inertiauk Active Member
    574
    29
    I got my IE rods from backdraft motorsport, but badger5 does them as well.
    I got my big end bearings off ebay.
  16. superkarl
    9,553
    2,453
    an agu can be picked up on ebay relatively cheap, and any parts not used can be sold to recoup some cash.
    bill @ badger 5 sells IE rods. backdraft motorsport also. a quick internet search will bring up a few. just be careful of import duty etc.
  17. superkarl
    9,553
    2,453
  18. Dani_B19
    9,336
    391
    Thought so, so you could run AGU pistons with uprated rods in our s3 blocks?
  19. superkarl
    9,553
    2,453
    yeh you could, making the CR 9.5:1.
    just gotta find a set, or someone willing to break their engine apart.
  20. Dani_B19
    9,336
    391
    Looking at that sheet, its says APY/BAM/AGU are all 9.5.1 CR!
  21. superkarl
    9,553
    2,453
    good spot! theres some conflicting info there, one sheet says 9.0:1.
  22. patTTpoa
    patTTpoa Member
    793
    Wow, cheers for all the info!
    I'm not in any rush, as I want to get it right first time, & now the engine has to come out I mite as well do the hardest jobs now.
    I'll do some searching over the weekend for rods etc.
    I'll keep you all up to date on what I'm doing, but anymore info/links would be great!
    Again thanks
    Pat
