New S3 engine
Gops Jun 24, 2013
  1. Gops
    3,198
    666
    I know it's nothing for an 8L but I thought I'd share what's totally new about the S3 8V's engine! Quite interesting at the turbo part:
    Engine
    The long-stroke 2.0 TFSI in the Audi S3 is new from the ground up. The only thing it has in common with its predecessor, which was named Engine of the Year in its category five times in a row between 2005 and 2009, is its displacement of 1,984 cc (bore x stroke 82.5 x 92.8 millimeters). The four-cylinder unit delivers a constant 380 Nm of torque to the crankshaft between 1,800 and 5,500 rpm. Rated power at 5,500 rpm is 300PS, and the engine redlines at 6,800 rpm.
    The S3 delivers impressive performance. The sprint from zero to 62mph is completed in 5.1 seconds when equipped with the S tronic transmission (5.4 seconds with the manual transmission), and top speed is electronically governed at 155mph. Combined fuel economy stands at 40.9mpg (manual 40.4mpg). This corresponds to CO2 emissions of 159g/km (162 in the manual version).
    The powerful four-cylinder engine features two balancer shafts rotating at twice the speed of the crankshaft for impressive smoothness, and with the help of an electromechanical sound actuator at the bulkhead this refinement is complemented by a suitably sporting engine note. The exhaust system also includes a sound flap that opens at certain engine speed ranges to give the S3 an even more purposeful soundtrack.
    The 2.0 TFSI boasts groundbreaking solutions in many fields of technology. One of these is the additional use of indirect injection. It supplements the FSI direct petrol injection at part load to reduce consumption and particulate emissions. FSI injection, which works at pressures up to 200 bar, is used when starting and at higher loads.
    On the exhaust side, the Audi valvelift system varies the stroke of the valves in two stages; the camshaft on the intake side can be adjusted steplessly through 30 degrees of crankshaft angle while 60 degrees of adjustment is available on the exhaust side. The compression ratio of 9.3:1 is unusually high for a turbocharged engine.
    The exhaust manifold is integrated into the cylinder head, where it is bathed in coolant. This solution lowers the temperature of the exhaust and accelerates warmup following a cold start, which lowers consumption during the cold-start phase. This concept also has a positive effect on fuel consumption during sporty driving because full-load enrichment is no longer necessary. The large turbocharger is also a new development. It achieves a maximum boost pressure of up to 1.2 bar for even more spontaneous engine response. A high-performance intercooler integrated into the water circuit greatly reduces the temperature of the compressed air and thus increases the amount of air required for combustion.
    With the 2.0 TFSI’s innovative thermal management system, two rotary slide valves consolidated in a single module regulate the flow of coolant. These valves ensure that the engine oil heats up to its operating temperature soon after the vehicle is started; they also maintain the coolant temperature, as per a given driving situation, between 85 and 107 degrees Celsius (185.0° F and 224.6° F). As a result – regardless of load or engine speed – the valves always strike the perfect balance between minimal friction and high thermodynamic efficiency.
    The 2.0 TFSI has been designed specifically for use in the new Audi S3. Pistons with stronger bolts and new rings plus reinforced connecting rods with new mounts transfer the power to the crankshaft. The gray cast iron crankcase has been reinforced at the main bearing seats and the main bearing cover.
    The cylinder head is made of a new, particularly lightweight aluminium-silicon alloy characterized by high strength and temperature resistance.
    An innovative coating on the piston skirts and mounting the balance shafts in roller bearings keep internal friction low. The regulated oil pump only consumes as much energy as is necessary for the current driving situation.
    Despite its complexity and high output, the new 2.0 TFSI weighs just 148 kilograms - more than five kilograms less than the previous engine. Its dimensions are compact: 603 millimetres long, 678 millimetres wide and 664 millimetres high.
  2. badger5
    9,510
    2,004
    sounds technically impressive
  3. Scullies
    Scullies Well-Known Member
    1,543
    657
  4. superkarl
    superkarl MAN OF STEEL
    9,496
    2,436
  5. Scullies
    1,543
    657
  6. Maverick1
    Maverick1 Member
    49
    Sounds pretty wicked, although I can just see 10 years down the track, all of these fancy bits and pieces being a tuners nightmare.
    dealership: "oh your balancer shafts need replacing? No worries, we have them in stock for 1200 euro. Each."
    Haha. In all honesty though sounds pretty sweet.
  7. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,267
    360
    sounds impressive. Makes it difficult to upgrade the exhaust manifold if its part of the head..
  8. mattyboy199
    mattyboy199 Well-Known Member
    1,897
    31
    If only i could 40mpg out of my 8L, being 300ps with that economy is excellant shame they start @ 30k
