new s line gear knob
gixxer600k4 Mar 20, 2009
  1. gixxer600k4
    gixxer600k4 Member
    692
    hi guys have just found a brand new s line gear knob with the perforated leather and i am just wondering how you take the old one on and replace it?
    cheers
  2. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,473
    610
    If you have an ash tray, open it and pull the trim round the gear stick up from the top and it will easily lift out
    Lift the trim up over the gear knob (turn the gaitor inside out) and you will then see a clasp which holds the knob/gaitor onto the gear stick
    This is just squeezed together so you can use a small screw driver to pry it open. Unfotunately you need a special tool to squeeze the clasp back on without damaging it
    However, it is not essential that you put this clasp back on - I didnt when fitting the S3 knob and hasnt given me any bother
  3. NHN
    29,521
    1,765
    Thats cause you're lazy :undwech:
  4. Boydie
    3,473
    610
    LOL I dont have the tool and pliers would have flattened it :p
  5. TripleD
    TripleD Audi S4 Avant Owner Team Mythos Audi S4
    712
    249
    43
    A hammer isn't a special tool, and can fix anything :yahoo:
  6. Jose_85
    Jose_85 Audi Noob
    57
    Boydie......
    You know the wheels on the car on your pic, you know how much they are?
  7. gixxer600k4
    gixxer600k4 Member
    692
    those alloys are the bbs ch, they are gorgeous alloys and they are pricey! depending on price abd colour they range between £330 to £390 per alloy
  8. Ash187
    7,505
    748
    gixxer600k4
    do you have a pic of the gear knob you bought?
  9. gixxer600k4
    gixxer600k4 Member
    692
  10. Ash187
    7,505
    748
    hmmm... looks nice,
    im still in love with the glowing S3 gearknob...
    http://translate.google.com/translate?hl=en&langpair=de|en&u=http://www.faudiq.de/anleitungen/Interieur/S3%2520Schaltknauf%2520beleuchten.htm
  11. gixxer600k4
    gixxer600k4 Member
    692
    yea i do like the s3 gear knob but as i dont have the s3 i dont really think it will go well!
  12. Ash187
    7,505
    748
    same problem i have, i wish they did a knob like the S3 chrome with red insert for the S-line... or even the same S3 knob without the S3 branding :(
  13. gixxer600k4
    gixxer600k4 Member
    692
    just purchased it! dont think it will be much difference, but will look better to me!!!!
  14. Ash187
    7,505
    748
    good luck mate,
    get some before and after pics as well :)
  15. gixxer600k4
    gixxer600k4 Member
    692
    yea will do mate! all i want now is a new steering wheel but they are soo bloody expensive. i feel that mine (on the a3 2003 8p) is massive, its the three spoke one
  16. emzino
    emzino Active Member
    1,231
    Nice one. Put up some pictures of each stage please. Mine has chipped a little and if it's cheap, might get a new one.
  17. gixxer600k4
    gixxer600k4 Member
    692
  18. gixxer600k4
    gixxer600k4 Member
    692
    ok mate, well its coming from germany so wont be able to do it that soon!!!
  19. Boydie
    3,473
    610
    £1300 with tyres my man!
  20. Ash187
    7,505
    748
    i had a look on that and rang the guy to ask him what he does, he has second hand ones which look like new for cheaper which isnt too bad...
    the flat S3 ones are really nice but then so is the price...
    instead i was lucky to find a nice guy on ebay called Neil who sold me the S-Line multifunction steering wheel for a really good price. going to be fitting that real soon...
  21. gregormac
    gregormac Member VCDS Map User
    34
    Hi,
    it was the 1st thing to "go" in my 2009 Sportback, , bought the knob from the same guy on Ebay. really fast delivery
    Easy to fit, had to unpick the existing trim and re fit but its n and its sweet.
    Dont wory, 10 min job and you wont regret it, I havnt
    G
    :w00t:
  22. PNH80
    PNH80 Low life livin' the high life.
    1,633
    I changed my S-Line gear knob/stick for the solid satin finish alloy knob.
    You have to lift up the gator and basically snap of the old ring clip. Get some 'hose' clip thingy's (about £1 each from Halfords...They adjust and tighten with a screwdriver). Use one of those to replace the ring clip to keep the stick in place.
    It does make a difference because there's a bit of movement in the stick if you don't replace it.
  23. gixxer600k4
    gixxer600k4 Member
    692
    finally got it delivered and fitted, thought it would be easy but turned out to be a bit more complicated.
    easy to get out, just lift up ashtray and get ur fingers behind the gear gaitor surround and pull up, it is a bit tough but it is only four clips that hold it in.
    these two pics are the clips that hold it in place
    pull it all the way up and over so you can get good access to the clip
    the clip is similar to a jubilee, there is like a metal bit the is holding it in place, i bent it straight and unclipped it, when i put it back on i didnt fit one, it feels fine but i will be getting a jubilee clip soon. once this is undone, just pull it off
    there are then four lugs which hold the gear gaitor surround in place, i pushed them in two at a time, top then bottom
    as you can see they are both different sizes, i then started to panic at this stage so went back on the page where i got it from and it said that for this to fit an 8p some modification might have to be might like changing the bracket.
    so i started to unclip all the staples
    here you can see how much difference there is
    for the new gear leather to fit around the existing bracket i had to cut the holes longer to fit around the clips.
    once i got it around the bracket, i fitted the original staple back in to hold it in place.
    once this is done, just slide it back in and clip it into place
    new one fitted
    old one
  24. Ash187
    7,505
    748
    nice write up,
    this will certainly help me in the future when i plan to change my gear knob.
