New RS4 - About those 'Ali' Mirrors?
wigginer Jan 9, 2007
  1. wigginer
    wigginer Member
    425
    Hi All,
    I've got a real problem that's niggling me after researching the B7 RS4 literature wrgd the mirrors. The literature states they are non-folding. Does this mean they don't fold back at all or don't fold back electronically?
    This may seem like an anal question but i've got limited garage door width access and it could make the difference insurance wise, should I chose to buy.
    Appreciate your help
    Clive
  2. C_Audiboy
    C_Audiboy Vroom Vroom
    822
    From what I can see in the brochure it looks like they are fixed, although I'd be very surprised if they dont fold at all :wacko: .
    But it does look that way unfortunately.
    I'm sure some lucky devil who owns a new RS4 will reply soon.......
  3. wigginer
    wigginer Member
    425
    Thanks for your reply.
    The brochure definitely gives that impression, however I would like to think that Audi don't compromise practicality for style ...
    I would also like to think that if I clipped someone (or vice verse) then the mirror would 'give' rather than snapping off & causing untold damage to door panels and potentially other drivers...
    I'll probably be into my local dealer this weekend if the forum cannot provide answer.
    Also agree, a simple question for existing owners ...
  4. Dazza
    Dazza Member
    53
    The standard mirrors on the RS4 Saloon and Avant do not fold at all.
  5. The911SC
    The911SC Active Member
    1,032
    Only the cabrio is available with the folding mirror option where they are simply A4 mirrors.
    The rs4 saloon and avant are indeed fixed and cannot be folded in even manually; they just 'detach' !
  6. The911SC
    1,032
    oh, and if you 'clip' something, they would completely detach...!
  7. wigginer
    wigginer Member
    425
    Thanks for your response. Now I'm even more confused (or maybe a bit thick!)
    1) Is there some mysterious reason why Audi should only offer folding mirrors on the Cabrio?
    2) Why should you want to detach the matt aluminium mirrors and if they do detach do they do so easily?
    Getting desperate now ...
  8. wigginer
    wigginer Member
    425
    Thanks all, it looks like I would need a garage door frame upgrade ...
  9. C_Audiboy
    822
    You'll be surprised at this; according to the Audi website my A3 is wider than the RS4 if you include the mirrors!!! :wtf:
    A3 = 1957mm
    RS4 = 1933mm
    I have the A3 in the garage every night - and I thought that an RS4 would never fit in there as its pretty tight with the A3 - but now it looks like it will........... mmmm interesting!!!
    How much are those RS4s again ha ha
  10. wigginer
    wigginer Member
    425
    It's down to actual mirror size as the body of the B7 RS4 is about 40mm wider than my B6 A4, but across the mirrors the B7 RS4 is narrower.
    B7 RS4 = 1933mm
    B6 A4 = 1937mm
    Suppose I have got 4mm less to negotiate, if I chose to go for the RS4 and take the risk.
    Garage access width = 1987mm
    That gives me ... 27mm per side ... shedful!
    Mind you before it was 25mm! ... will that 2mm make all the difference?
    I will have to start practicing taking my A4 in and out of the garage with wing mirrors unfolded. If I can do it consistently with 25mm per side I am sure I do it with 27mm per side.
    Anyway this conversation is getting a slightly bit 'anal' ... I''ll get my coat!
  11. jamiekip
    jamiekip Guest
    Ha ha, good luck!!! :)
  12. marriedblonde
    marriedblonde Active Member
    4,371
    Yes but you don;t park the car square in the garage!
  13. wigginer
    wigginer Member
    425
    You've lost me there! ... mmmm! ... no you've not!
    As a matter of fact I do normally go into the garage at a slight angle and that could make it slightly easier...
    Don't ask me to explain why ... or draw a picture! it's Trigonmetry stuff
  14. wigginer
    wigginer Member
    425
    Well so far since thsi post I've managed it twice a day no problem! ... it's gettin serious ...
  15. joost
    joost Active Member
    1,169
    If you really wanted, you can buy the folding mirror assembly and retro-fit. Allparts South West Ltd do them for B5 and 6. Dunno how you control them though, I'm aasuming you'd have to buy the correct mirror switch.
  16. wigginer
    wigginer Member
    425
    Well I've decided to take the risk and I'm putting my order by mid-Feb .. it'll go in! ... it will definitely go in!!! .... it will absolutely definitely go in!!!! and ... if it don't ... I''ll have to change the bl**dy door!!!!!!!!!!!!!!!
  17. silver75
    silver75 Big Ron
    3,265
    .....saw on "the audi channel" the programme "your RS4" and the ginger fella says the mirrors fold manually but not automatically. The presenter woman asked him specifically.
  18. wigginer
    wigginer Member
    425
    Thank you my friend ... I've reserved myself to the fact that they will not fold either electronically or manually. I've been practising taking my current A4 (B6) in and out of the garage without using my folding mirrors and so far no problem. It's a few 'mills' wider than the RS4 at it's widest!
    If they do in fact fold back then that will be a bonus !!!
  19. silver75
    silver75 Big Ron
    3,265
    ..having said that though the guys who actually own RS 4s say they dont fold at all :shrug: if you have sky look out for the programme "your RS 4" on 884 or just go down to a dealer and check yourself?
  20. wigginer
    wigginer Member
    425
    Summary: Consensus opinion- they don't fold-back ... Amen!
    Thank you all :)
  21. wigginer
    wigginer Member
    425
    So is there anyone out there who is prepared to buy my 'fine example' of a A4 3.0 QS from me?
    Apologies to the Moderators, but I just have to get a 'plug in'!
    (probably off-topic, off-thread etc)
  22. C_Audiboy
    822
    Mileage?
  23. wigginer
    wigginer Member
    425
    Approx 45k
  24. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    And we're not kidding! They don't fold at all, not in any way, shape or form.
    I wanted the auto-dimming folding mirrors on my RS4 Avant - but the factory refused to build it until we took them off the order!
  25. bond
    bond New Member
    hi the mirrors on the rs4 dont move they are fixed
    .i have 1
    thank wayne
