New Road Angel - A common Fault ?
Andy101 Mar 10, 2006
  1. Andy101
    Andy101 Active Member Team Ibis Audi A6 Audi Avant Owner Group Black Edition
    249
    44
    My New Raod Angel is approaching twelve months old. Recently its begun taking a while to locate satellites (3-4 miles), but on occassion I've driven for 20 minutes. Is this a common thing, may have to get it sent in for a closer look.
  2. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    I've had mine for 18 months and it always picks up within about 30 seconds
  3. rickquattro
    rickquattro Member
    589
    Mine did a similar thing then failed to pick up any satelites at all. Sent it back to Blackspot where it needed a new GPS engine. No quibble, fast return, no charge. Excellent service, but boy did I miss it while it was away!
  4. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,419
    2,981
    Mine can take up to five minutes on occasions. I might ring them & see if I can wangle a free upgrade.
  5. scbduke
    scbduke Member
    55
    Had a similar problem with my RA Nav, failed to pick up a satellite for about 20 mins. I've found that rather than putting the unit into standby mode with the button on the front if I turn if off completely with the one on the base then on again it picks up a satellite almost straight away - I guess it clears any duff entries out of the way and allows a clean start.
  6. fallmonk
    fallmonk Turbo Sport
    1,868
    I had a loan of mates "navman" and a couple of times it threw a wobler and couldnt find a satellites for ages as well ! tryed switching off and re-booting didnt work , just had to leave it till it found them!
  7. DIPS_A4
    DIPS_A4 SEAT LEON CUPRA R (225)
    570
    i found my road angel does not pick up any redlight cameras even if i have installed the updates is that also a common fault?
    ive got road angel 2 with laser alert
  8. AndyMac
    9,832
    46
    Ermmm it's a speed camera detector, the clue's in the name.
    You can't really jump a red light accidently.
  9. Andy101
    249
    44
    [ QUOTE ]
    [/ QUOTE ]
    When you got the GPS engine repalced was it in warranty ?
    May give it a go anyway.
  10. AndyMac
    9,832
    46
    I feel naked without mine (I share it with the wife after mine got nicked), the accurate speed readout is just so reassuring somehow.
  11. rickquattro
    rickquattro Member
    589
    [/ QUOTE ]
    [/ QUOTE ]
    Hmm. I think so but not sure. Given the response that I had from them, I wouldn't be suprised if they helped you out after the warranty has expired. As I said, no quibble or attempts to wriggle out of getting it sorted.
    I know what you mean when you say that you feel a bit vunerable without it.....
  12. Andy101
    249
    44
    [ QUOTE ]
    [/ QUOTE ]
    If you have the unit number blackspot shoutbe able to disable your nicked unit i think.
    Will tryand blag a repair on mine
  13. AndyMac
    9,832
    46
    Yes I did this, but doesn't really help me. The scum that stole it is hardly likely to have the intelligence to even try and synch the database. Blackspot can't disable the actual unit as it is only a receiver, all they can do is disable any updates.
  14. 205man
    205man Active Member
    1,072
    14
    ive got a road angel classic and it wont find any signal? blackspot told me it was due to the audi windscreen but if you lot are getting a signal then it must be the unit
  15. fallmonk
    1,868
    anyone running the road angel plus , and how does it stack up against the Origin B2 ????
    wots the better item?
