New Prosport Rolling Road Day 25th October
JustCharlie Oct 9, 2008
  1. JustCharlie
    JustCharlie Member
    295
    Hello people,
    I'm organising a rolling road day at Prosport Stockport, a place I know a few of you are familiar with, with a few pals from GolfGTI.co.uk. It will be on Saturday 25th October, price is 40 quid a car, but a fiver of this will go to a charity of our choice. You'll get up to 6 runs to get the best figure for your car and will get a print-out just like last time. Peter will also put some refreshments on. There are also some lads coming from SeatCupra.net so could turn into a bit of a Tfsi shoot out.
    We can make a list here if you like listing car and spec, or you could add your name at:
    http://www.golfgtiforum.co.uk/index.php?topic=92214.msg785348#msg785348
    Looking for 20ish cars total, but will do a reserve list as we all know not everyone can make it nearer the time.:yes:
    Gaz
  2. jonnyc
    jonnyc Member
    858
    Prosport need a better way of keeping the cars cool, very important when your dyno testing a highly tuned car especially as the temps can go through the roof in a matter of seconds..
    Is there any indication that they will have any more cooling on this day?
    Jonny
  3. JustCharlie
    JustCharlie Member
    295
    I mentioned this to Peter when I had my car mapped there, his explanation was because the system the rollers use doesn't load the car as such through the rollers, the heat build up by the engine isn't as great as braked rollers because the engine isn't working so hard, if this is enough to compensate for airflow on the road or the big fans other systems use I'm not sure
  4. jonnyc
    jonnyc Member
    858
    Ah ok I see.. Still I think your know what im talking about, I would be well up for it again, especially as I have now got the big turbo kit on the car..
    But that puts me off, as my car is running pretty high power etc heat build up will be more of an issue..
    You could also post this on S3-talk.com some of the guys on there may be up for it!:)
    Jonny
  5. JustCharlie
    JustCharlie Member
    295
    You could just get him to do a couple of runs so heat soak isn't such an issue. I know everyone would like to see your motor and how it performs:hubbahubba:
  6. Vtec Abuser
    Vtec Abuser Member
    320
    13
    I for one look forward to seeing it JC.. ;)
  7. JustCharlie
    JustCharlie Member
    295
    nobody interested then?
  8. powerplay
    powerplay Grrrr
    182
    How can a Dyno measure the engine's maximum power if it doesn't push it to its maximum load? Indeed the "brake" of bhp refers to act of applying a load to resist the rotational force of the engine until the point at which the engine is no longer able to overcome the braking effect.
    But I'm sure someone will explain...:)
  9. ZBOYD
    ZBOYD New Member
    22
    From my experience the TFSi doesn't suffer so much from heatsoak as quickly as the 1.8T's do. I would probably like to see some larger fans being used at ProSport too though.
    Yet my own car produced very repeatable figures at Prosport to other RR's it had been on including Awesome GTI where they have a large fan setup.
    It should be a bit colder too at the end of this month than it was when we went to ProSport in July, nice denser air. :icon_thumright:
    Jonny, have you uprated your intercooler now for your Stage3?
  10. jonnyc
    jonnyc Member
    858
    No still running with the S3 intercooler, its very good actually! Inlet temps never go above 38 degrees on runs and quickly recovers back to 35 after a couple of mins..
    As soon as I go the next step in terms on power on the car ill be upgrading the intercooler
    Jonny
  11. L60N
    L60N Guest
    I'd be up for Prosport. Just interested to see what gains teh GIAC has given..
  12. EAGLE79
    EAGLE79 Member
    339
    I'll be up for it fella.
    Missed the last one and i'm dying to know my car BHP! Count me in!
  13. JustCharlie
    JustCharlie Member
    295
    nice 1, I'll start a list then:), and add your names to the list on GolfGTi.co.uk
    L6ON
    EAGLE79
  14. jamiekip
    jamiekip Guest
    Turns out I'm going to be up north so will venture over for this too - get a second set of results on my car for comparison!
    I'm interested to see what Leons pulls with the standard air box versus mine with with carbonio and BMC panel....
    Put my down for it too JC, but I'll be coming over from the North East so a later slot if possible.
    J
  15. block
    block Member
    255
    When do you need to know by? as jamie might have persuaded me down as part of a mini test of giac mapped s3's.
    i do fancy it but im supposed to be working so i might need to try and wangle the day off.
  16. JustCharlie
    JustCharlie Member
    295
    End of the week really pal
  17. JustCharlie
    JustCharlie Member
    295
    L6ON
    EAGLE79
    jamiekip
  18. jamiekip
    jamiekip Guest
    Ha ha ha - shall we just do the VAG com stuff there then mate?
  19. jamiekip
    jamiekip Guest
    Word!
    If it's easy enough lets just do it at pro sport!
  20. Vtec Abuser
    Vtec Abuser Member
    320
    13
    Over 20 names now guys and a nice mixture of ED30/S3/Cupras to compare.. Looking forward to it..
    I'll put you on the list Mitch..
  21. RobinA3
    RobinA3 Well-Known Member
    1,828
    47
    I am up for this, can someone put my name down for a run too please.
  22. JustCharlie
    JustCharlie Member
    295
    we have got 20 names but I'm sure we can squeeze you in pal if its a deffo
  23. RobinA3
    1,828
    47
    yeah its a defo, i'll only need 2 runs if possible, one bluefinned and one standard.
  24. JustCharlie
    JustCharlie Member
    295
    your added to the list pal
  25. RobinA3
    1,828
    47
    thanks
    what time do we need to get there for on Saturday?
  26. JustCharlie
    JustCharlie Member
    295
    will let you know, gonna speak to Peter at Prosport on Monday, Tuesday.
  27. JustCharlie
    JustCharlie Member
    295
    Ok fellas, spoke to Peter at Prosport today and he has confirmed a 9.00am start.
    Cars will be grouped together with type so there is less set-up time on the rolling road.
    [​IMG] Gaz S3
    [​IMG] Neg GTI
    [​IMG] bacillus GTi
    [​IMG] john_o ED30
    Rob GTI
    [​IMG] Luca ED30
    [​IMG] Ben ED30
    [​IMG] Joesgti GTI
    [​IMG] MAT ed30 GTI ED30
    [​IMG] mikebgti ED30
    [​IMG] Zboyd Leon Cupra Mk2
    Ste-lfc Leon Cupra Mk2
    Shaunthebeef mk3 16v
    [​IMG] L6ON S3
    [​IMG] EAGLE79 S3
    [​IMG] jamiekip S3
    [​IMG] Hurdy Standard ED30 standard my ar5e
    [​IMG] Mitch 78 S3
    [​IMG] RobinA3 2.0Tfsi quattro
    [​IMG]=confirmed
    With regard to a chosen charity cancer related ones are most popular, with macmillan being mentioned regularly so unless anyone has any objections we'll go with this
    cheers, give me a shout if I've forgotten anything [​IMG]
  28. jamiekip
    jamiekip Guest
    Good work mate - No Block though :( was hoping to catch up with him
  29. EAGLE79
    EAGLE79 Member
    339
    looks like you'll be there to here my noise then Jamie, i'm just before you!
    ha ha
    Bring ear plugs LOL
  30. EAGLE79
    EAGLE79 Member
    339
    Oh and the graphs will show any loss of power during the noise! Over 4k
  31. JustCharlie
    JustCharlie Member
    295
    No running order sorted yet fellas, gonna leave it till the day
  32. block
    block Member
    255
    I was hoping to come down jamie but unfortunately the spaces filled up before i could confirm if i could get out of work:Flush:
  33. jamiekip
    jamiekip Guest
    Think there may still be slots - Just Charlie????
  34. JustCharlie
    JustCharlie Member
    295
    ye still a couple of slots, let me know
  35. L60N
    L60N Guest
    Guys, im going to have to pull out.. Took a rather large financial hit out of the blue this morning and as such cant really spare the cash on this occasion which is a bit sh*t as I was looking forward to seeing a plot with the GIAC..
    Maybe next time :sorry:
  36. EAGLE79
    EAGLE79 Member
    339
    Come along anyway!
    Excuse to do nothing and look at cars! It will be DIY for you otherwise!
  37. Vtec Abuser
    Vtec Abuser Member
    320
    13
    Yeah Leon, finance isn't a good enough excuse.. lol
  38. L60N
    L60N Guest
    haha. Grrrrrr.
    How much is the RR? £50 ish?
  39. jamiekip
    jamiekip Guest
    £40 mate - come along, it'll be a laugh. Is Noel coming too?
  40. JohnS3
    JohnS3 Active Member
    3,032
    Do you think he meant fiancé? maybe sporting a swollen black eye!
