  1. thehogester
    thehogester Member
    60
    First of all nice to meet you all, recently bought myself a 2.0T S Line in silver on a 55 plate.
    Got a few little issues id like to sort.
    First off is the glovebox hinge, ive been told this is a common weak point and theres options for DIY fixing it.
    Next up is the clips on the arm rest need replacing.
    Lastly is finding a way of connecting my iPhone up to the stereo.
    I realise theres a search function, but id also like to introduce myself to you guys. I've fallen in love with my A4, so ill be on the forum quite often no doubt.
    Thanks in advance for any help/replies!
  2. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,480
    646
    well the armrest needs a new lid
    the glove box can be fixed i just sorced a sh one from ebay
    theres a few ways to get iphone to stereo someone wll be along soon to advise on options
    and welcome
  3. phil_w
    phil_w Active Member VCDS Map User Audi A4 Audi Avant Owner Group S-line owners group Team Brill Red
    577
    53
  4. hades-
    9,480
    646
    worth a try for the price
  5. Paul B7
    Paul B7 Active Member
    622
    34
  6. thehogester
    thehogester Member
    60
    Cheers for the links guys, cheap and cheerful fixes suit me down to the ground!
    Just need to sort an iPhone connection. I quite like the look of the standard stereo, just seems cleaner keeping it. However I feel an aftermarket head unit with a USB port on the front would be the easiest option.
    I've got the Bose speakers and 6 cd changer in the broken glovebox haha. I'm never going to use the cd changer though.
  7. A4Ade
    A4Ade Member
    102
    20
    I have an XCARLINK - this allows you to use your existing headunit controls in a fairly basic way. With my Symphony II I can control FF/RW and skip tracks etc from the HU and steering wheel. It uses the CD changer (CDC) connection on the HU, but also allows you to keep the changer plugged in too if you want. Has an aux connection too for basic audio pads through.
  8. thehogester
    thehogester Member
    60
    Mines the Concert (single din version), would it work with that do you know?
  9. A4Ade
    A4Ade Member
    102
    20
  10. thehogester
    thehogester Member
    60
  11. Cjb
    Cjb New Member
    14
  12. thehogester
    thehogester Member
    60
    Can anyone help explain how the Bose system is setup exactly? It has it's own amplifier separate to the headunit? Is that right? So would an aftermarket unit be able to power the system, or would you run the pre outs into the existing Bose amp?
  13. Emmo
    Emmo Member
    224
    12
    The BOSE system does have a separate amp, an aftermarket unit will power the system as long as you buy the correct harness to go with it. You will also need an aerial booster aswell.
  14. thehogester
    thehogester Member
    60
    Does this look right?
    http://www.caraudiodirect.co.uk/audi-active-wiring-adaptor.html
    What is the aerial booster for? Sorry if that's a stupid question.
    So with an aftermarket headunit, is the Bose amp still in use?
  15. Emmo
    Emmo Member
    224
    12
  16. thehogester
    thehogester Member
    60
    Thanks for that! So does the headunit amplifier power some of the speakers, or is the Bose amplifier powering all of the speakers?
  17. thehogester
    thehogester Member
    60
  18. thehogester
    thehogester Member
    60
    A little update: I've ordered the clip to fix the arm rest lid. I'll let you guys know how it goes, hopefully well!
    I also wanted to ask you guys if there's any well known issues that are worth rectifying? Anything likely to go that's worth fixing now?
    I've been reading that the 2.0T is designed to run on super unleaded, so I'll be putting a tank of vpower in next.
    I've got to say I'm loving being an Audi owner now! I'm very much converted to vag!
  19. Molnboman
    Molnboman Well-Known Member
    1,338
    193
    I've got to say I'm loving being an Audi owner now! I'm very much converted to vag![/QUOTE]
    Glad you are enjoying your new car, and may wish you all the best with it. Plus one with you on the fuel. My 2.0t does not like 95 ron and rattled like a bast@rd until I changed to 98. Can't tell any difference between Shell V Power and the other 98 brands...although I would use Shell VPower over the others given the choice.
    Other issues....You should check if the Diverter valve has been changed. Makes a big difference if yours is gubbed. HOW TO REPLACE VW AUDI DIVERTER VALVE - VAG DIVERTER VALVE DIY 2.0T - 2.0T DIVERTER VALVE DIY - YouTube
    If your water temp is not bang on 90c you'll maybe need a new thermostat unit. The needle should be bang on 90. If not you'll use more fuel.....which am sure you can do without.
    Other than that, IMHO I would take your off any long service oil changes ( if your car is on it ) and switch to full synth' oil and filter changes instead. I have always changed mine at 10k km's regardless of time ...I know it's a very emotive issue amongst Forum members, but something I have always done with cars I have owned with turbos. Cheaper than a full tank of gas.
    Check this excellent write up too on the 2.0t engine issues. If for a Volkswagen but it's the same engine type as ours. Common issues, tips and tricks for the 2.0t FSI BPY engine | 2006 GLI worklog
    Allan
  20. thehogester
    thehogester Member
    60
    Great reply there mate, thanks for that! Is the diverter valve a pretty easy job or worth going to a garage? I've recently realised there's a vw/audi specialist based very locally to me.
  21. Molnboman
    1,338
    193
    No worries, you'll get plenty of advice on here.....just maybe a bit slow right now to reply cause of holidays and stuff but you'll get an answer or an opinion pretty sharpish usually. If you are handy wae a spanner, then you could probably do the diverter valve yourself. I don't have any tools up here so use a local independent....think they charged me an hour labour...think it takes about half an hour...the part if I remember is about around 40 quid....it's the cheapest mod you can do...and the most effective if yours is the old type as in the YT link I sent you.
    A
