Reverse and number plate lights are in the tailgate.
Is there a harness allowing you to simply connect to those lights from boot area?
Number plate wires are on one plug with boot/tailgate handle switch.
I’ve tapped into the wires directly behind the connector as further along there is a control module of some sort, I think.
Relay and resistor secured to tailgate with screws and nuts.
Wires for number plate lights at the plug/connector are the two internal ones (second and third out of 4). Yellow/grey being positive feed.
Two external ones (first and forth out of 4) are for the handle switch.
Rear fogs and indicators are accessible from both boot sides or just one? If one, which one?
You running Saloon, aren’t you Steve?
They can’t be different than Avant’s.
Mine is an Avant, I traced the pins using ELSAWin, there are a couple of different options so this is definitely correct for the rear lights being part LED or 'highline' as they are referred to in the software:-
Front Left Indicator
T12 - 12-pin connector black, connector B - onboard power supply control unit
grey / black
Pin 10
Front Right Indicator
black / yellow
Pin 9
Front Left Fog
T10 - 10-pin connector black, connector A - onboard power supply control unit
black / yellow
Pin 7
Front Right Fog
white
Pin 3
Rear Left Reversing Light
T15 - 15-pin connector brown, connector A - convenience system central control unit
blue / red
Pin 6
Rear Right Reversing Light
black / green
Pin 8
Rear Left Fog Light
T32d - 32-pin connector blue, connector B - convenience system central control unit
green / red
Pin 9
Rear Right Fog Light
green / blue
Pin 8
Rear Left Indicator
red / grey
Pin 3
Rear Right Indicator
red / grey
Pin 4
Warning, when I disconnected connector B on the onboard power supply control unit my headlight washers came on non stop! I disconnected the battery so I could unplug to access the wiring.
I have today had an error flash up for my front fog lights, reckon I may need to swap for a lower load resistor, I used some 6ohm resistors I had laying around which seem to be fine for the indicators, measured the fog bulb I took out and it's coming up at 0.5ohm, wondering if a straight wire would suffice? Might be risky.
The click is audible in mine, the relays are in a plastic box which is then tucked up behind the onboard power supply control unit which is in the driver's footwell. It doesn't really bother me though, could potentially wrap the box in wadding to dampen it if I was bothered.
