New member (Hi!) and a problem:(
Discussion in 'A6/S6/Allroad forum (C5 Chassis)' started by rio678, Mar 20, 2007.
  1. rio678
    rio678 New Member
    Mar 20, 2007
    Hi everyone
    i wonder if you can shed some light on this, My 1996 Audi A6 2.5 TDI auto, it acts up sometimes, car sometimes is juddery when going and yesterday the glow plug light was flashing when i was going along. What does this mean? i checked my owners manual but nothing about it.
  2. Advert Guest Advertisement
  3. bigblokey0
    bigblokey0 Member
    Jul 5, 2006
    745
    sorry cant help ya as i aint got a diesel but welcome to the site
  4. L1 HCS
    L1 HCS Active Member
    Oct 10, 2006
    4,600
    Hello & :sign_welcome: to the site.
  5. rio678
    rio678 New Member
    Mar 20, 2007
    Thanks for the warm welcome ;)
  6. maxlbrown
    maxlbrown Deep Blue
    Jan 26, 2006
    248
    Check the MAF as it is generally the first point of problem. iwould suspect the ECU may be at fault as well hence the glow plug light. Best bet is find some one close to you with vagcom and check it. there seems to be a number of people on the site with it and are up north so you should not need to look far.
    Sorry not to much help.
    Welcome any way
  7. matt_o121
    matt_o121 2.8Q
    Nov 1, 2006
    84
    the coil light also works as an engine management warning light if it is flashing when you are driving along it is indicating a fault.
    the general fault when this happens is a fault with the brake light switch.
    get someone to check the operation of your brake lights as a starting point.
    the bake light switch has two curcuits one operates the lights the second tells the engine ecu you are braking.
    if the two curcuits are not working together it indicates in the form of the flashing coil light.
    it MAY also give you a small running fault in that the ecu retards the engine when you are braking.
    worth a try for the price they are.
    matt
