New Member Here
eddy_turbo Sep 23, 2012
  1. eddy_turbo
    eddy_turbo Turbo!
    9
    Just like to say Hi as i have just signed up and am new to this :)
    So i bought myself and Audi S4 B5 on friday night. I bought the car knowing there was a problem with it. It did say the car needed a clutch so i didnt bother testing it i just put it straight onto the back of the truck and took it home.
    Had a check over it yesterday to find i can not get into 1st or second gear weather or not the car is running. It went straight into 3rd no problem at all and drive fine into 4th, 5th, 6th and reverse with no sign of slipping from the clutch.
    Just wondering if anyone has any idea what it could be? i am hoping its just a cable or something and not the gear box :/
    I do have a few plans for this but will update once i decide on what i am going to do ;)
  2. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    27,831
    10,935
  3. eddy_turbo
    eddy_turbo Turbo!
    9
    Been told it may need new gearing and synchro rings :(
  4. Sandra
    27,831
    10,935
    Well that sounds a bit expensive, hopefully its something else. :) x
  5. Bradderz_1988
    3,988
    261
    1/2 syncro are a common problem on the 01E box !! New genuine ones are stronger so get one from stealers or you will only be doing it again !!
  6. LeeT
    LeeT Member
    429
    Whats involved in changing the synchros? Just wondering if its worthwhile me doing whilst ive got the engine and box out
  7. Broken Byzan
    13,237
    466
    To the OP It's common with the S4 01E boxes, I think i saw this one on Egay, was 1600 iirc. So at that price a used box for a few hundred quid still makes it a bargain tbh.
    Lee, not sure, I am pretty sure it's something best left to specialists
  8. LeeT
    LeeT Member
    429
    Hmmm, mine is OK. Its just quick shift between 1st and 2nd that can be a bit hit and miss
  9. aragorn
    18,612
    872
    Its a progressive issue.
    The synchros on 2nd get weak causing missed shifts. The grinding that results from the missed shift damages the shift collar.
    If you never grind the gears, and just live with having to take 2nd gear easy, then it'll go on for a while like that.
    It only takes one particularly hard grind and you end up with a box like the OP's
    The fix involves new synchros and a new shift collar, its about £500 in parts, plus labour for a transmission specialist to strip the box and fix it.
  10. eddy_turbo
    eddy_turbo Turbo!
    9
    Yes it was the one on ebay. Got it cheap so not fussed about paying to fix it really. There is another gearbox on ebay at the minute i might try get hold off but failing that i will repair this one.
    Is it an engine out job or can it be dropped out with the engine still in
  11. LeeT
    LeeT Member
    429
    Its awkward but it will come out without the engine
  12. eddy_turbo
    eddy_turbo Turbo!
    9
    Ah nice one. Anyone have any idea what 1st and 2nd gear synchros will cost me from audi
  13. LeeT
    LeeT Member
    429
    As Kev(Aragorn ) posted below i would assume. £500 :(
  14. eddy_turbo
    eddy_turbo Turbo!
    9
    I have managed to source a gearbox for now and will rebuild mine over time. Noticed you can get a longer 6th gear for these as well what will give you a higher top end what would be ideal for the ring trip next year B)
    The car needs a few bits and bobs to get it mint again but will have to post up photos once i get the car back from the garage so people can tell me whats what.
    Thanks for all your help so far
