New member considering A3 1.9 / 2.0 TDi
sdutton007 May 7, 2013
  1. sdutton007
    sdutton007 New Member
    Hi everyone,
    I've just joined this forum as I am planning to replace my 2005 Focus Ghia 1.6 Ti-VCT with a A3 1.9 / 2.0 TDi. The focus has been a good car, but is drinking too much (partly due to my heavy right foot) - averaging about 32MPG, and it seems so slow to me.
    I've been told by various people to go for the 1.9 as the 2.0 is unreliable and has a tendancy to blow up - is there any truth to this?
    I don't know much about Audis in general, but are there any specific models that I should avoid?
    I am also considering putting a Bluefin on it, although I have seen mention on here of something called "custom code" but didn't find much about it on Google.
    Thanks!
    EDIT: I've also seen that the 2.0 TDi 170PS has problems with the DPF, and the ECU needs to be 'unlocked' so I think I will avoid the 170PS unless anyone can tell me otherwise?
    EDIT 2: I've seen a lot of mention of CR and PD engines - Can anybody provide a link detailing the differences cheers!
    SPARTAN91 likes this.
  2. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    27,687
    10,767
    Hi, welcome to audi-sport.net. Where are you located? You should start out reading the faqs threads in this section. You will get plenty of help and advice from the others, there is a lot on knowledge on this forum. Enjoy. :) x
  3. sdutton007
    Cheers. I'm from Cambridge. I did have a look over the FAQs but didn't see anything regarding 1.9 vs 2.0 TDis
  4. Sandra
    27,687
    10,767
    ​One of the guys will be along shortly with advice. :) x
  5. soulsurfer
    soulsurfer Member
    146
    9
    I can't comment on the 2.0 TDi blowing up as I'm new to owning one, after owning a 1.9, although I've not heard of them blowing up, but what I can say is that the 2.0 is a much nicer engine with more power on tap, I'd go 2.0 every time ;)
  6. SPARTAN91
    SPARTAN91 RED FIVE STANDING BY Regional Rep Team Silver Audi A3 TDi
    484
    167
    43
    Hi there
    Go for the 2.0tdi 140 as yes the 170,s do have DPF issues.I,ve had my 2.0tdi 140 for nearly 2 years and because it is the common rail spec engine it does have DPF but I've had no issues with it yet.You can have have the DPF removed with no after issues but I haven't bothered with that. But on the plus side I have just remaped my car using the Superchips bluefin and it has made a big difference and well worth it.
    I'am also in east anglia just in Norfolk and this foram has an East Anglia section if you wish to join.
  7. SPARTAN91
    484
    167
    43
    CR stands for common rail (fuel) not sure what PD is
  8. Lee540
    Lee540 Member
    123
    10
    Go for a 2.0TDi 170, 2009 onwards with CR common rail diesel engine. Plenty enough power and torque, not supercar but be a bit better than your Focus. No DPF issues with CR 170
  9. percymon
    percymon Member
    156
    How many miles a week do you do - any engine with dpf is likely to give some issues if all you do is short town commutes, or the rush hour crawl. The exhaust needs to be hot with plenty of gas flow to keep the dpf in good condition, otherwise it will self regenerate (burn excess fuel and increase revs at idle) as a means to try to clean the dpf - if this fails then its a garage job to have it cleaned through or replaced.
    The PD engines are pumpe duese or something like that ! they are older technology, at the time fairly high fuel pressures injection and very reliable in the main but their power delivery is a bit on off - flat at low revs and then the kick of the turbo. Common rail is more modern technology, uses very high fuel pressure (ca 1400 Bar, 20000psi) and better electronic control for improved efficiency. CR is all well n good but a replacement fuel pump is £1200 at a main dealer (I had a failure on my Mk6 Golf under warranty).
    PD is more tolerant of short journeys, although the later years of these 1.9 engines also featured a dpf filter.
  10. sdutton007
    I should have mentioned earlier that I am planning to get one made around 2005 - I believe the Focus is worth around £2800 and I'm willing to put in a bit extra, but I won't be able to afford anything newer and I won't consider finance.
    I do 4 x 5mile journeys every workday, and then 2 x 20 mile journeys nearly every day.
    I think a Common rail engine without a DPF would be best for me personally. Do they do a non-DPF CR140?
    Also, can anybody point me towards a A3 buyers guide with:
    - model differences
    - engine options with pros and cons including reliability
    - optional extras
    - info on the facelift (what changed, etc)
    - what S-Line and Black Edition are
    - etc
    Thanks!
  11. lgooch
    lgooch Well-Known Member VCDS Map User
    1,195
    168
    1.9 tdi is usually only 105 BHP and will be no quicker than your focus with the year you are looking at.
    However bombproof and does not suffer half the potential issues that the 2.0tdi could. Having said this I have owned both and had no issues with either.
    PD engines are less refined and more rattly where as the later CR engines are quiet, refined and dare I say it more petrol like in terms of character.
    All good cars in their own right. Just depends what you want from a car. Economy, refinement, performance as the A3 can provide it all. Just depends how deep your pockets are.
  12. percymon
    percymon Member
    156
    Can't help out with when the dpf started but somewhere around 2004/5 would seem plausible given other manufacturers were around that time.
    Assuming a £5-5.5k budget you're going to be looking at something with over 70k miles on the clock so service history and general condition is absolutley key. There are 170bhp examples on autotrader is you want to risk one with 130k+ miles. There are plenty of examples of PD engines with well over 150k miles on the clock and with good maintenance they should run another 100k miles.
    SE spec was basically the base model, Sport generally added sport suspension, bigger wheels and different seats. S-line was more sporty again, harder suspension and bigger wheels.
    Black Edition spec only available for the last few years, so too new for your budget.
  13. sdutton007
    Cheers.
    I will be looking to get a similar spec to my Focus (air-con, cruise control, total closure, heated front & rear windscreen). Climate control would be nice, as would a double-din space for the stereo (but I don't think this is standard on any A3?).
    I'd like it to have a balance between sport and comfort - I do quite high mileage and my mum uses the car for long journeys, so it needs to be fairly comfortable and not crash into every little bump, but I don't want much body roll on corners.
    Sorry to be a pain but I am rather picky when it comes to choosing a car! Thanks for your patience!
  14. SPARTAN91
    484
    167
    43
    If you want a non PDF A3 you will have to get a PD140 as all the CR spec engines have DPF which is from about 2008 onwards but PDF's can be safely removed,at extra cost mind you but this will effect your buget.There is also alot of spec info if you look up A3 on wiki p.
  15. sdutton007
    I just got some advice from Jabbasport, who said that the 140 models around 2005 suffered from porous heads, and poor fuel economy compared to the 1.9. They recommended either the 170 model with the DPF removed, or a PD130 or PD150.
    Can anybody confirm this?
  16. mjr901
    mjr901 Guest
    I can confirm that the best thing to do is to 'gut' the DPF and go for the 170.
    You have to map the DPF out of the equation but it's the best way due to it being MOT friendly as the DPF is still 'there'. (but not...)
  17. percymon
    percymon Member
    156
    There is no problem with a dpf provided you do enough miles at decent speeds and temps - I never had a forced regen in 65k miles and 3.5yrs with my Golf. I did advise my father to go back to petrol since he does a lot of short journeys to and from the golf club (5 miles) - Oh to be retired :(
  18. lgooch
    1,195
    168
    You should be able to get a 1.9tdi 105bhp sport and get a remap up to 130bhp
    It will be nippy, economical, more reliable than the 2.0tdi for the year your looking at. Not too crashy and a blend of decent ish handling and comfort. Should also come with dual zone climate as standard. Nearly everything else is an option !
  19. sdutton007
    I'd like something a bit more powerful - even with a remap, it would barely beat my Focus...
    The PD130 or PD150 would be much better - but according to Wikipedia, these engines are only available on the pre-2003 model :(
    Is there any diesel A3 8P model with the following???
    - at least 130 BHP standard
    - no DPF
    - no porous head
    EDIT: According to Wikipedia, the BKD engine kicks out 140PS without a DPF. If/when I decide to buy one, is there an easy way to tell which cars on AutoTrader/Pistonheads/etc have the BKD engine ? Thanks
  20. lgooch
    1,195
    168
    So you seem set on a 140tdi with the BKD engine.
    You had better get saving a bit more if you want one which avoids the porous head as you will be looking at a later model which fetch more money unless you want one with intergalactic mileage.
    Would you not consider a Golf GT with the same BKD engine ?
    I am not sure when they brought in the DPF on the 140 but I had a 57 plate golf which did not have a DPF so I think it would have been 08 onwards if not later which is could be beyond your price range anyway.
  21. lgooch
    1,195
    168
    The PD 130 and 150 are the old pump Duse engines and are only 1.9 litres
    Found very commonly in old a4, a3 and mk4 golfs
    They will be a bit old for what you want.
  22. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    Don't know all about the Diesel engines BKD and all that but, don't get a 1.9. My mate's got one and it barely moves, even in compared to mine and mine isn't exactly a rocket!
    Get a 2.0TDI, either 140 or 170. Get DPF removed, if you're worried about it, and remap, jobs a good 'un.
  23. icekay
    icekay Member
    79
    I have a 58 plate A3 2.0 tdi 140 and it has dpf
  24. sdutton007
    I'm coming to the conclusion the Audi A3 is not suitable for my needs.... either they have porous heads, a DPF or no power :(
    I would consider a Golf, but won't this suffer from the same problems?
    According to wikipedia, all of the 8P A3's have a DPF apart from the 1.9 105PS and the BKD. When did they fix the porous head on the BKD, and how do you tell whether a car has the dodgy head or not?
  25. lgooch
    1,195
    168
    Have a search on here for porous head. There is a massive thread on here which tells you everything you need to know and what cars are affected. Did not affect the golf from what I believe
  26. SPARTAN91
    484
    167
    43
    Spec wise A3's only have heated rear screens
  27. sdutton007
    I've searched but not found anything definitive.
    I'd expect better from a "premium marque" :S
  28. SPARTAN91
    484
    167
    43
    It all because ford have the patent on the heated front screens as part of there climate package.I also had a ford focus before my A3 and it had a heated screen and auto dim rear view mirror both of which I miss but I never have regreted changing cars even more so now it remaped.
  29. lgooch
    1,195
    168
    Search for "how to know if your cylinder head will crack" et voila
  30. sdutton007
    Shame Audi decided not to licence the technology... oh well, it's not a dealbreaker for me.
    I read that thread, but it has nothing definitive - it basically says before mid-2005, they are ****... mid-2005 to mid 2006 were a bit better.... mid 2006 onwards were better again but some still do crack. :S
    That rules out the BKD engine - I'm going to be going for 2005-ish, and don't want the hassle/expensive of replacing the head.
    I believe that only leaves me the option of the BMM-140 or BMN-170 engines with the DPF either gutted or removed... assuming these engines are better & more reliable?
    Am I right to assume gutting the DPF involves a long screwdriver and a big hammer? (That's how I 'gutted' the cat on my GT Turbo lol). Will the ECU cope with this, and will it affect the MOT?
