New MAF but still low g/s in vcds...
SiGainey Sep 2, 2011
  1. SiGainey
    SiGainey Member
    506
    9
    Following on from sandips logging session this week, I've put a new bosch MAF in and I'm still getting slightly low readings (154g/s) following a full throttle 3rd gear run. Anyone had this before?
  2. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,486
    First port of call I'd check would be:
    1) check for boost leaks in hoses (even the slightest cut from an over-tightened jubilee clip can cause this). Check all hoses around / under DV etc.
    2) Check DV - does it seem OK (holding boost etc.)
    When was it last serviced (when was air filter last cleaned)?
  3. SiGainey
    SiGainey Member
    506
    9
    Serviced last month, air filter good. Dv is not a standard one (but is a recirculating one). Have leak tested it recently and only found one leak which is now fixed
  4. SiGainey
    SiGainey Member
    506
    9
    Bump :)
  5. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Join the gang mate, i've had a leak for a few months now and still can't find the bastard thing. Looks like i'm gonna have to get a pressure test done!
  6. Broken Byzan
    13,237
    465
    some of you guys need to get to Bills or similar for a smoke test/diag. I am sure they could identifty leaks etc with the tester.
  7. SiGainey
    SiGainey Member
    506
    9
    Yeah, I agree but he is a 250 mile round trip!!
  8. finesse
    finesse Active Member
    2,805
    Shirley this is an electronic issue? MAF just measures air going in at entry of system not at throttle body.
  9. Jacko4130
    Jacko4130 Goodie Gum Drops
    848
    There must be a local garage / Tuner with a smoke tester??
