New logs as requested
s3gazz Dec 13, 2010
  1. s3gazz
    s3gazz Well-Known Member
    1,383
    105
    a couple of runs from tonight
    Any info appreciated cheers
  2. s3gazz
    1,383
    105
    can anyone tell me anything from my logs cheers
  3. <tuffty/>
    21,962
    4,229
    Yarp, your map is running on the lean side for power... looks more like a std map because of it (in answer to your pm)... load value looks odd... Bill?
  4. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I would get a tried and trusted map put on....IMO
  5. badger5
    9,637
    2,073
    It does look lean under boost for my liking...
    how is timing pull on block 020 during these runs?
    what is the running fault you are trying to resolve? I missed that bit
  6. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    020 is listed in the first image dude?
  7. badger5
    9,637
    2,073
    really?
    missed that then.. doh!
    I cant see the images from this POS corporate network I am currently on..
  8. Welly
    10,696
    130
    LOL, what you need is some good IT gear.... :).
  9. Welly
    10,696
    130
    Between 5700 and 6600 CFs are regularly up to and including 6s, so quite high.
  10. badger5
    9,637
    2,073
    lol, you're right.. and I believe I am receiving said It gear and able support also, from a very good local guy we both know.. :D
    corporate web filtering kills anything photobucket related.... w4nkers
  11. Welly
    10,696
    130
    See these (you owe me Gaz):
  12. s3gazz
    1,383
    105
    cheers tuffty going to mapping garage soon they said they will add some more fuel cos im not happy lol
    should do job ryt in first place
    whats the load value is it my injectors mate
  13. s3gazz
    1,383
    105
    def going down that route when i get full system on going through all this again lol
  14. s3gazz
    1,383
    105
    cheers bill just wondering if map is ok car car not going to blow up and i keep getting limp mode when i drop it a gear and put foot down getting fault saying check dv presher drop , maximum presher exeded some days as well dont make sense
    do i need to get timing changed as well tar gaz
  15. badger5
    9,637
    2,073
    lots of issues on there are'nt there..
    all fine before remap was it?
    check for leaky hoses... random stuff occurs when there are leaks...
    map could also be the issue if its done this from the outset
  16. s3gazz
    1,383
    105
    def in need of some IT gear then
    i owe u welly
    cheers gaz
  17. s3gazz
    1,383
    105
    CHECKED ALL HOSES NOTHING FOUND I AM MISSING THAT RUBBER BUNG THAT GOES UNDER THE VVT VALUE THO COULD THAT BE TO BLAME
    IT JUST A BACK STREET GARAGE MAP SAID HE HAD 20 YEAR EXPERIANCE MY **** LOL
    AND YE MAP WAS DONE FROM THE OUTSET BILL
  18. badger5
    9,637
    2,073
    no what I was asking was did these problems occur before the remap?
  19. s3gazz
    1,383
    105
    no they did not happen before i had it mapped bill just had a new map put on so ill put the logs on here latter see the differance
    the guy that mapped car before did not add any fuel or up the torqe at all left it all standered boost was all over the place and timing was sky high see what ya think to my next logs tar gaz
  20. badger5
    9,637
    2,073
    this all sounds a bit iffy mate - no more fueling? but its running more boost?
  21. s3gazz
    1,383
    105
    i just been told and seen from the grafs of the old map he did not add anymore fuel to the map and torqe he just messed with timing and
    boost new map has everything altered ill get some logs up
  22. badger5
    9,637
    2,073
    good luck fella
