Can anyone point me in the right direction. I've listed just the faults rather the entire list. I gathered the ABS sensor is just a replacement sensor on the rear hub. But the rest are abit of a baffle.
Chassis Type: 8P - Audi A3/S3
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 47 52 55 56 57 69
75 76 77 7D
VIN Number: WAUZZZ8P66A116323
Address 03: ABS Brakes
Controller: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Coding: 0021121
Shop #: WSC 06314
2 Faults Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
003 - Mechanical Failure - Intermittent
008 - Implausible Signal - Intermittent
Address 08: Auto HVAC
Controller: 8P0 820 043 M
Component: KlimavollautomatH17 0260
Coding: 0196608
Shop #: WSC 06314
1 Fault Found:
00483 - Control Module for Auxiliary Air Heater
013 - Check DTC Memory
Address 09: Cent. Elect.
Controller: 8P0 907 279 F
Component: Bordnetz-SG H36 1201
Coding: E4885F01B214100000160000160000000008FA175C0100
Shop #: WSC 06314
1 Fault Found:
00988 - Lamp for Brake Light; Right (M10)
012 - Electrical Fault in Circuit - Intermittent
Address 17: Instruments
Controller:
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 25: Immobilizer
Controller:
No Faults Found
Address 42: Door Elect, Driver
Controller: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0000760
Shop #: WSC 06314
1 Fault Found:
01030 - Central Locking Key Switch; Driver Side; Lock
Address 46: Central Conv.
Controller: 8P0 959 433 C
Component: KSG H04 0050
Coding: 188000186D088F0FC89FC63300
Shop #: WSC 00666
1 Fault Found:
00956 - Key 2
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 7D: Aux. Heat
Controller: 1K0 963 235 E
Component: PTC-Element 0404
Coding: 0000000
Shop #: WSC 00000
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
75 76 77 7D
Coding: 0021121
Shop #: WSC 06314
2 Faults Found:
Coding: 0196608
Shop #: WSC 06314
1 Fault Found:
Shop #: WSC 06314
1 Fault Found:
Controller:
No Faults Found
Controller:
No Faults Found
Coding: 0000760
Shop #: WSC 06314
1 Fault Found:
Shop #: WSC 00666
1 Fault Found:
00956 - Key 2
Coding: 0000000
Shop #: WSC 00000
1 Fault Found:
014 - Defective
