New LED Lights and Xenons Retrofit
PTTM Aug 10, 2008
  1. PTTM
    PTTM Pedal to the Metal!!!
    85
    Quick one chaps!!
    Is it possible to replace my current standard headlamps for the new LED Running Lights and Xenons?
    Im aware some tinkering will need to be done for autolevellers and washers. Can the lights and other bits be bought yet?
    If so part numbers and where to get them.
    Most appreciated!
    PTTM
  2. Issac Hunt
    1,162
    Anything is possible if your pockets are deep enough, these lights wont be cheap. Parts from the usual sources, Audi dealer, or VAG parts may be able to order them for you.
  3. Khufu
    Khufu Well-Known Member
    5,704
    31
    If the rear lights are available then I guess the front will be. Cant say for definate but the feeling is that the wont fit as they are different shape.
  4. golf
    golf ***** rent boy VCDS Map User
    1,556
    The facelift headlights are different in shape to the current ones so you'll have to change the wings, bumper and bonnet.
  5. maars
    maars Full speed ahead
    576
    Just saw a set on ebay.de ...
  6. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    So they'll be euro spec then.
    I think current bi-xenons cost about £700 each so the new ones will be a bit more. But as Golf said they won't fit anyway!
  7. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    9
    What he said......
  8. PTTM
    85
    ******! lol
    Thanks anyway.
