  1. I need to replace my standard s3 (99) head unit (bose upgrade)because im suffering from the apparently common problem of a dodgy volume control that seems to either turn the volume to min, or to maximum with just one small adjustment.
    Is it just a case of changing them over or does the the fact that it has the bose upgrade mean that is is not very compatable??
    Also heard that Audi is the best place to get head units surrounds from -is this correct and how much would it be?
  2. T3RBO
    T3RBO 6th Gear
    131
    Got that fault with mine /ubbthreads/images/graemlins/frown.gif
    With the fact I need a new CD changer I am now considering a headunit & changer package
    Wouldn't go to Audi (££££) so would also be interested in, if concert h/u removed I guess aftermarket won't be a straight fit so where can you buy a surround from?
  3. dunk
    dunk Member
    770
    which head unit is it?
  4. not sure, its pre facelift model
  5. T3RBO
    T3RBO 6th Gear
    131
    Mine is a standard concert unit, pre face lift /ubbthreads/images/graemlins/smile.gif
  6. AndyMac
    9,832
    45
    You'll need wiring adapters if you are only upgrading the HU. The Bose system uses a 4 channel amp for the cabin speakers and separate sub amp. These are delivered via mini ISO connectors on the HU, so you will need the Bose active wiring adapter to hook into this.
    Adapters are all readily available from caraudiodirect and elsewhere.
    The fasicia surrounds are all a bit ****, but the Audi ones are better than most. Don't, whatever you do, get the Autoleads ones, they are terrible.
  7. thanks for the help
  8. AndyMac
    9,832
    45
    you should be watching top gear!
  9. are the amps seperate units?
    will a new £120 - £150 head unithead unit sound any better/worse than the existing bose one
  10. i am wathing it!!
  11. AndyMac
    9,832
    45
    It will sound loads better. The existing HU is not Bose, it is an entry level Panasonic, with some Bose EQ settings programmed into it.
    There is a 4 channel Bose amp in the right rear cubbyhole, and the sub amp is inside the tupperware box housing the "sub".
