New head...cost?
JBL Oct 16, 2012
  1. JBL
    JBL New Member
    19
    Hi all, anyone got ideas on how much a new head for the 8L s3 would cost? And any reccomendations on where to look / buy?
    Any help would be much appreciated.
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Ive got a large port AGU head pm,d
  3. <tuffty/>
    20,903
    3,713
    New heads vary between 700/800 quid to around 1200 from a dealer IIRC... why do you need a new head and do you need a bare one or a fully built one? also which year? as APY (pre facelift) S3's are different to AMK/BAM (facelift)
    Bill @ Badger 5 has some heads kicking around that may be of use...
  4. badger5
    9,404
    1,944
    std smallport APY head here... just come off a bottom end we have used on another job.
    fully built as it came off. £150+delivery
  5. Yohan87
    Yohan87 Member
    426
    12
    Got any reconditioned large port heads Bill out of interest?
  6. badger5
    9,404
    1,944
    not currently.. one is due in.. AGU which I would need to get re-guided and skimmed.
  7. Andrew@A.L.D
    3,873
    609
    Bugger just sold a ported large port head that someone decided they didn't want anymore
  8. Yohan87
    Yohan87 Member
    426
    12
    How much would that go for Andrew? PM if you don't want to post public.
  9. Andrew@A.L.D
    3,873
    609
    £450 but it did have loads done to it and the guy picked it up
  10. Westy
    Westy Well-Known Member
    17,443
    1,103
    I paid £150 for my AEB head then I paid £350 for a whole overhaul.
  11. Broken Byzan
    13,237
    465
    AEB large ports are the way forward...
  12. Westy
    17,443
    1,103
    Is there any difference between the AEB and AGU large port heads or are they identical?
  13. Yohan87
    Yohan87 Member
    426
    12
    Port sizes are the same I believe.
  14. s3dave
    10,110
    736
    As a rough guide i payed around £400 for a light skim..oil stem seals...all inserts/guides ,5 exhaust valves 3 x inlets and new tensioner guides....all built back up and good to go....
  15. JBL
    JBL New Member
    19
    Cheers for reply, need a bare head but have heard that you need new valves as once disturbed they tend to go wrong when the heads refitted and engines used. I got a 2001 facelift amk. I d'nt know enough about engines to explain the problem but the car is with Dave Turner in stonehouse, his sons run TRD in stroud, thought you may have heard of them if you live in gloucestershire. But in very simple terms coolant is getting into the head through one of the guides and somewhere else. Its washed one of the pistons clean and one of the spark plugs was corroded quite bad.
  16. JBL
    JBL New Member
    19
    Hi dave, i pm'd but not sure if it worked as i had no messages in my sent folder, its a 2001 amk facelift, would the agu head fit? if not any reccomendations where to look? cheers
  17. <tuffty/>
    20,903
    3,713
    Yeah... have heard of TRD... Bill @ Badger 5 knows them too (also in Stonehouse)...
    You don't need a new head and you can reuse the valves and other running gear too... AGU is large port but if you don't have plans for more than stage 2 power then not much point in fitting one tbh... biggest issue with used heads is valve guide wear in particular exhaust guides... get them checked and replaced as required... AMK's (and maybe BAM's too) seem to suffer more from cracking as they run a little hotter than earlier S3's (APY's)... you can also use heads from the AUM engines too (K03 turbo'd cars like 2001> A3's etc)
    I tend to make a judgement call on which parts look less worn.. Audi's were mostly on variable servicing whereas SEAT's and other VAGs were on fixed... if you get a decent head then there is no reason not to use it complete tbh...
    If coolant is getting in then I suspect its cracked between the exhausts... like I said, AMK's seemed to suffer for cracked heads...
  18. badger5
    9,404
    1,944
    I have used smallports on the shelf if you need one
  19. JBL
    JBL New Member
    19
    Cheers for the detailed reply tufty, much help. Bill i may try pop in 2mo on my lunch break to your workshop if thats ok?
  20. badger5
    9,404
    1,944
    yea I'm here.. pretty much always
