New gearbox shopping list
mephisto Apr 18, 2011
  1. mephisto
    mephisto Member
    249
    17
    Finally got round to affording a new well 2nd hand low mileage gearbox for my S3.
    Now as it's a 2000 and has done about 120k ive been told i should also fit the following
    Clutch kit
    Dual Mass flywheel
    I guess the clutch is an obvious one, is the dual mass a necessity, anything else i should consider, CV boots or mounts of sorts or may have to pay for when having it swapped out.
    thanks.
  2. quattro1
    quattro1 Member
    639
    cv joints can be inspected while the jobs being done but its not really worth just changing them while the gearbox is out because theyr easy enough to get to anyway, just what you've stated really, its deffo worth getting the clutch done, flywheel can be inspected and replaced if needed
  3. Broken Byzan
    13,237
    466
  4. Westy
    Westy Well-Known Member
    17,443
    1,105
    Big +1. You dont want that git going on you in a few months and have to get the box out again.
  5. mephisto
    mephisto Member
    249
    17
    Thanks for posts, so to summarise
    Clutch kit - replace
    Dual Mass flywheel - inspection.
    Clutch slave cylinder - replace
    So i should just go ahead and order clutch kit and slave cylindert as the dual mass flywheel may be ok??
