New Forge TIP (AWW one) on AGU with K03s
abdus Mar 12, 2008
  1. abdus
    abdus Top Gear VCDS Map User
    1,827
    Got my new Forge TIP from
    J Racing Parts and Tools (JParts@live.com), (great service I must say)...delivered next day with quote, receipt and shipment direct from Forge.
    Going to fit it soon. BTW it's an AWW engine code TIP going on an AGU with K03s. Any fitting guide would be much appreciated
  2. Bong Water
    Bong Water In two minds
    786
    My mate had one of these fitted to his Leon on Saturday, you are going to love it mate, car pulls stronger, holds boost longer and sounds even better than it did before
    Do you mind me asking how much you paid? From what I can see it was a pain in the **** to fit on the Leon, my mates was fitted at Awesome GTI
  3. abdus
    1,827
    £104.65 delivered which is a very good price as far as I'm aware...
    can't wait to fit and will post back results when done :)
  4. Prawn
    11,667
    3,669
    Not totally sure on the AWW engine, but I think you will need to plug a take-off at the top of the inlet near the MAF.
    Mine was an AGU forge hose, with a take off cut into it to suit an AUM, and then I've got it and plugged the hole up again!
    If it has the un-needed take-off, forge sell 10mm plugs to plug it.
  5. Bong Water
    786
    That seems a good price, my mate paid £119 plus fitting
  6. abdus
    1,827
    I took advice from Dave regarding the AGUS with K03s and the AWW TIP
  7. Dave_Bayern
    Dave_Bayern Slipping at 3.5Krpm
    1,913
    The biggest problem you will find is clamping the TIP over the turbo inlet itself.
    Its an absolute nightmare!
    I took mine off at the weekend and after 3 hours of swearing I went looking for my normal TIP to re-fit it, then remembered I'd sent it to you!
    I eventually got it, ended up using a Mikalor clamp kinda halfway over the metal inlet but still fully on the TIP.
    Basically jubilee clamps pull the pipe off the inlet, and its a pain, Mikalors do this but eventually seem to bit, I assume as they have a completely circular clamping motion whereas jubilees go egg shaped.
    There is a normal fitting guide on seatcupra.net
  8. Jimmeh
    Jimmeh Active Member
    1,438
    Bumping this topic slightly...
    Does anyone know, or have access to this TIP fitting guide?
    Just purchased a Forge TIP and the 007p DV from Damian @ DPN (very useful/helpful chappie)
    Any help appreciated.
    Jim
    **EDIT - Just found an article on a VW site. More info can be found here - http://www.ottawa-vdubbing.com/forums/phpBB2/viewtopic.php?t=8651
