New flywheel to cure idle wobble
Rigla Feb 14, 2011
  1. Rigla
    Rigla S Line
    So,
    I had a new clutch and flywheel fitted to see if it cured the common wobble on idle problem...Did it work?
    No!
    GGGRRRR!:banghead:
  2. ~RS~
    ~RS~ Active Member
    1,466
    22
    Have you checked the torsion timing?
  3. Harrelson
    Harrelson Member
    173
    I have this too, mine didn't get fixed because the problem didn't appear during the testdrive and its so random i haven't bothered to go back.
    Keep us updated on what is going to happen/solutions
  4. basssound
    basssound Member
    203
    10
    I have the same problem, get a wobble on idle but mine sometimes takes a couples of times to fire up :/
  5. mike foster
    3,967
    Presumably you have all read the many threads on here about this ?
    Common cause of this problem is the injector wiring loom. The loom has been updated to cure the problem iirc.
    EDIT - you will be interested in this thread on another forum :-
    A3 TDI PD injector loom issues - Audi Mag | VAGOC.co.uk
  6. Sharkie1976
    Sharkie1976 Member
    185
    15
    Sorry to dig up and old post, but did you find out what caused the judder and the poor starting?? Mine is exactly the same mate.
