[ QUOTE ]
Gambba said:
As you put at the beginning of this post another option in stainless steel filtration was Blitz, who can provide a filter which is only 90mm long and 113mm at the top flaring too 150mm and a neck of 124mm. That's the Blitz C4 version which should in theory from what Rich has said fit nicely inside the filter box....but they are a bit more expensive. The other problem is that the neck is has an OD of 124 so the ID would also be kinda large, so would need an adaptor of some sort, as the adaptors for it are more expensive than the filter by the looks of it!
Might pick one up while I'm across in Japan on business as it's probably cheaper, but I'll check with some friends of mine.
well that's food for thought anyway. /ubbthreads/images/graemlins/beerchug.gif
[/ QUOTE ]
The price is why i didnt go for that one... I thought £120 was a bit steep for something that might not work.
The filter diameter of the QSR filter, is perfect... exactly the riht size... couldnt fit anything bigger inside the box, but its just the extra 20mm or so. When i get it all finished, i will tkae alot more detailed picures inside and out, so that people can see EXACTLY what i have done. What would be ideal, is if there was a way of angling the pipe inside that the filter attached to, just 20o or so, just so it could sit inside the box completely.
But nevermind... learn from mistakes!
Rich
