New faults!!!!!!!!!!!!!!
acano May 24, 2010
  1. acano
    acano Member
    108
    Hi all, left the house and the car started misfiring.
    stuck it on VCDS which threw up these codes:
    4 Faults Found:
    16804 - Catalyst System: Bank 1: Efficiency Below Threshold
    P0420 -- 001 -- Upper Limit Exceeded
    17771 - Cylinder 3 Ignition Circuit: Short Circuit to Ground
    P1363 -- 001 -- Upper Limit Exceeded
    16697 - Misfire(s) Detected: Reason: Lack of Fuel
    P0313 -- 001 -- Upper Limit Exceeded
    16691 - Cylinder 7 Misfire Detected
    P0307 -- 001 -- Upper Limit Exceeded
    I know what the problems is with the first one (o2 sensor) but what about the rest?
    thanks Tony
    A4 2.0 SE 2001
  2. paul20v
    paul20v Audi fanatic
    1,114
    Hi
    i would be more inclined to say the first one is a cat efficiency problem
    cylinder 3 ignition circuit sounds like a coil / ignition problem
    as for a missfire on cylinder 7 thats a good one on a 4 pot
    sort the first 2 out and you may find the others wont come back as a few fault codes are often symptoms and causes of others always go with the first ones that make sence to your symptoms
    have you cleared the codes also to see what returns its always worth a try just incase theres old codes in there that somebody didnt erase after fixing previous faults
    hope this helps
    Paul
  3. acano
    acano Member
    108
    I counted out the cat as I only just had it MOT'd and emissions were fine, thought the second one (17771 - Cylinder 3 Ignition Circuit: Short Circuit to Ground, P1363 -- 001 -- Upper Limit Exceeded) may be coil pack but wasn't sure and had no idea about the others.
    I resently checked for fault codes (just before MOT) so it isnt any old codes left on there, so I'll buy new coil packs and see how it goes.
    thanks for the reply Tony
  4. paul20v
    1,114
    Hi
    cats can still pass the mot but be out of there efficiency as far as the ecu is concerned as its out of its tolerences ,
    ive got a customer who has had a cat efficency fault in his memory for 3 years and its still passing mots
    he says he will change it when it fails the test
    personally the light being on would annoy me also you dont know if any other faults come up as the light is always on
    unless of course theres an obvious symptom such as a missfire which is unmissable
    Paul
  5. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,386
    112
    ive had the same fault (16804 - Catalyst System: Bank 1: Efficiency Below Threshold ) for 2 mot's now, its deffo the cat, not the sensor, i changed the sensor in hope but didnt make any difference
  6. acano
    acano Member
    108
    Thanks paul I never thought of that and your right clearing the fault and light for the cat is a pain, but always thought it was the sensor because of passing the emissions test, so looks like a new cat!
    But it'll come after the coil packs now:crying:
    Tony
  7. acano
    acano Member
    108
    Oh well new cat it is then!
    thanks Tony
  8. acano
    acano Member
    108
    Right maybe someone can tell me why this is, I cleared the fault codes and its running as it was before the fault came, still slightly hesitant but nothing to bad. Would this be the coilpack and if so why would it be ok now? surely if it is faulty it wouldn't reset?
  9. paul20v
    1,114
    Coil packs can be intermitent and will get worse when hot ,
    you also have plugs and connections that are worth checking ,
    im not saying the coil isnt at fault but sometimes the wiring or connections can be too blame everything is worth checking .
  10. NHN
    29,577
    1,779
    That threw me too, strange huh
  11. acano
    acano Member
    108
    Well a round trip of 60 miles and all feels fine, however still gonny change them! So would anyone know where the best place to buy replacement coil packs at a resonable price?
    regards Tony
  12. johnnythepie
    johnnythepie Well-Known Member
    2,242
    76
    you need to pm pjmspeedy
