New fault after coding CC on a 2007 A4
@udi A3 Feb 17, 2013
  1. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,820
    197
    Just wondered if anyone has come across this? I emailed rosstech but its bugging me. Fault was not present before coding CC, and coding was sucessfull. This is the after log after a DTC reset and a drive.
    Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb
    Part No SW: 03L 906 022 JN HW: 03L 906 022 B
    Component: R4 2,0L EDC H01 3174
    Revision: 11H01---
    Coding: 010C002C02072118
    Shop #: WSC 06335 123 12345
    ASAM Dataset: EV_ECM20TDI03L906022JN A01004
    ROD: EV_ECM20TDI03L906022JN.rod
    VCID: 7AFB4C23FDCB18C86F8
    1 Fault Found:
    4332 - Check Coding of ECUs on Powertrain Data Bus
    P1647 00 [032] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 133693 km
    Date: 2013.02.17
    Time: 20:00:23
    Readiness: 0 0 0 0 0
    The only other code present is
    Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
    Part No SW: 8K9 827 851 HW: 8K9 827 851
    Component: J605 Master H24 0240
    Revision: -------- Serial number: 8K9827851
    VCID: FBF5C9277AF1A1C0F4E
    Subsystem 1 - Part No SW: 8K9 827 852 HW: 8K9 827 852
    Component: J756 Slave H24 0240
    2 Faults Found:
    16347 - Control Module - EEPROM Error
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 57
    Mileage: 133693 km
    Time Indication: 0
    Date: 2013.02.17
    Time: 19:49:26
    02242 - Rear Lid Lock Button in Luggage Compartment (E406)
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 57
    Mileage: 133693 km
    Time Indication: 0
    Date: 2013.02.17
    Time: 19:49:26
    Could they be linked? The 01 engine fault was not there before coding but the bootlid issue was.
  2. NHN
    29,345
    1,719
    This came up on an 07 A4, strange as one of the part numbers doesnt even fit the B7 A4, confirm the year & chassis type, maybe a B8 08?
  3. @udi A3
    1,820
    197
    Sorry it was a b8.
    Rosstech suggested recoding gateway to same value again to see if fault resets.
    havent tried as yet.
