new engine help?
black s3 Mar 19, 2012
  1. black s3
    black s3 Member
    43
    the oil pump went on my s3 which has caused bottom end to dry up (im guessing) so im just wondering would a golf gti 150bhp turbo engine lump fit using my gearbox turbo ecu etc so its still running like a s3? if so is it worth doing or to much hastle?
    any help would be appreciated
  2. s3joe
    s3joe Active Member
    570
    86
    There is a lad up here splitting a s3 as the turbo blew I can give you his number if you want.
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    yes the turbo golf blocks will be fine mate...
  4. black s3
    black s3 Member
    43
    yeh the only problem is the s3 engines pick up quite alot of money thats why im after a golf 1, and theres a few around dwn here
  5. black s3
    black s3 Member
    43
    thanks anyway tho :)
  6. black s3
    black s3 Member
    43
    cheers mate, will it fit in just as easy as the bam lump?
  7. s3dave
    10,110
    736
    yes you just swap all your gear over to it ...manni turbo and inlet, etc as yours got VVT? if so the head will need changing too, or at least the cams and controller
  8. <tuffty/>
    21,686
    4,116
    If the Golf engine is an AUM then it will have 19mm gudgeon pins and not the 20mm pins of the S3... try and get a AGU from a Golf/A3 if you can...
    If you have an APY then a BAM engine doesn't have SAI so you will need to do a delete and also change the cam chain tensioner to the non VVT off yours... if yours ia an AMK then the BAM is a straight swap..
    You can use more or less any transverse 20v turbo engine and just mix and match the good bits from yours... 150/180 engines run higher compression ratio than S3's but not really an issue... both Welly and I run higher comp pistons with no issues...
  9. black s3
    black s3 Member
    43
    its the bam engine in mine, do you think its to much work? any rough prices? got a mechanic that will do mates rate
