new discs to go with my calipers!!
jcb Oct 9, 2007
  1. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    very excited
    360x34 on 5x112 stud pattern.
    4 pot Brembos need to squeeze the discs in as there is not much room!!
  2. naefeart
    naefeart Bonkers
    168
    39
    Wow those anchors should stop you no problem.
    Tbh I wouldn't have thought they would fit :think:
    What wheels are you using?
    N
  3. jcb
    4,132
    13
    18"s. fit should be OK as the hat height is pretty high (depth from hub face to disc centre)
  4. Randomjim
    Randomjim Active Member
    2,752
    :sign_pics:
  5. PaulJC84
    PaulJC84 Owner
    2,914
    17
    Cool, what model they off?
  6. jcb
    4,132
    13
    pics of what?
    discs.....VW Phaeton! ssshhh don't tell anyone
    calipers......Cayenne
  7. Randomjim
    2,752
    Sorry pic didn't show up first time, they are monsters!! When are you getting them fitted?
  8. tracer
    tracer '96 a4 1.8 se
    266
    wooya beastie
  9. jcb
    4,132
    13
    have to get the wheels this week next week, have a spare strut to test fit and fine tune the adapters and then they are going on. 2 weeks hopefully.
    looking at some rs4 rears to match up with them (312mm)
    may sound overkill on a 1.8t, but I have a 2.1l 20v running a GT2871 going in over Christmas, expecting somewhere north of 350...at the wheels!
  10. PaulJC84
    PaulJC84 Owner
    2,914
    17
    I think we need to meet up so I can see some of these mods when you get them done!!
  11. Markey
    Markey Active Member
    2,175
    WOW there going to be awesome make sure there are loads of pics taken when fitting and fitted :)
  12. Biglockie
    Biglockie Aye you know it makes sense
    1,032
  13. Markey
    2,175
  14. jcb
    4,132
    13
    Update!
    Just picked up a full set of RS4 brakes (calipers and discs)
    Going to test fit the discs as they are the same size as teh Phaeton disc but sooooooo much lighter, think VW make em out of lead!!
    Anyone want the front calipers?
  15. Biglockie
    1,032
    PICS??????
  16. dummi
    dummi smoking a6
    1,210
    stg 5 ecs kit just fits under 18"s hopefully yours will too
  17. jcb
    4,132
    13
    RS4 disc on spare strut
    RS4 Disc and 4 pot brembos lined up inside 18x8 RS6's (from behind)
    From the front
    Still can't believ how much lighter the discs are than the standard Phaeton disc, less hat height which concerned me but it all fits!!, off to the engineers now for four adapters
  18. jcb
    4,132
    13
    not worth it, you can get RS4 rears (312mm) for next to nothing, always coming up on eBay as the B5 owners go to B7 RS4 rears.
    I just got rear calipers, discs, pads, Front Discs and cailipers all for £300.
    Calipers will sell for £100+ by themselves.
  19. Markey
    2,175
    so are the rs4 disk a straight swap or do you need the hubs etc?
  20. jcb
    4,132
    13
    discs bolt straight on, same stud pattern, the tricky bit is matching the lug pattern on your strut to the lug/radial pattern on whatever calipers you use.
    I have lug mounted brembos so I need a plate with four holes to extend the caliper mounting point towards the tyre (distance from hole to hole) and also to line it up with the disc (plate thickness)
  21. Biglockie
    1,032
    I'll keep my eyes open for that fella, cheers
  22. Biglockie
    1,032
    Are you making these yourself dude I'm in the same boat and might need carriers made, fitting cupra R brembos
  23. docurley
    4,071
    86
    Adapter made on the cheap would be good as I am looking at fitting my RS4 setup this week end if I get the last few parts in on time but later I would like to upgrade the calipers.
  24. Biglockie
    1,032
    A template made up and then a group buy maybe?????
  25. jcb
    4,132
    13
    well my plan is to get a few patterns made:
    A4 and S4 (two different adapters) I have a spare S4 strut
    Fronts:
    1) lug mounted Brembo four pot with RS4 discs (360x32)
    2) same caliper with Phaeton discs (360x34)
    A4 only
    Rears:
    RS4 discs with RS4 calipers (312mmx 20 something)
    Then I have some adapters to sell on and make up some of the cost of my conversion.
    Doing the same the same with the tubular 1.8t turbo manifold for the B5 chassis......just been busy recently
  26. PaulJC84
    PaulJC84 Owner
    2,914
    17
    Sounds like it, would be good having somewhere to get adaptors pretty cheap.
  27. jcb
    4,132
    13
    one more adapter that I will have:
    for the A4 and S4 to fit RS4 discs and calipers
  28. Biglockie
    1,032
    I'm up for this, i was thinking of doing the rear conversion as well, i've got an S4 hub coming but if we can do the conversion on standard A4 hubs then thats even better
  29. docurley
    4,071
    86
    Don't think anyone does the S4/RS4 adapter for the A4 that I know off.
  30. jcb
    4,132
    13
    that was the idea...not much point me doing them if you can get them at Demon tweeks
    Anyone interested in flange adapters for bigger OEM brakes to go on their A4/S4?
  31. macca
    macca Member
    525
    yes i am interested as this is on my list of urgents, fitting weitec coilovers this weekend, then mot and next month probably get onto brakes or if you have some stuff which will help, then i'll wait. i'm looking for around 360mm 4/6 pots, i can get 6 pot calipers on a 360mm or 380mm disk for £1400 using new parts.
  32. docurley
    4,071
    86
    If you can make a set quickly I will by a set and test them as my RS4 set-up is waiting to go on.
  33. Biglockie
    1,032
    Doc are you puttin gon fullset of RS4 brakes, front and rear???
  34. jcb
    4,132
    13
    Jesus! I would hope so.
    Set of new SR4 discs went for £375 last week on eBay
    My calipers were only £250 or so
    I would want the whole lot including S/S pipes for that dollar.
    Anyway, off to the engineer tomorrow
    Will let you know how quick they can turn them around.
    Found myself a goodridge dealer in Edinburgh who will make custom pipes for a decent price as well
  35. docurley
    4,071
    86
    I have the full set including hubs dive shaft even anti roll bars and rear subframe diff and prop just missing a gear box. The fronts are the first point as I have a Barring issue so they have to be done first.
    JCB keep me posted and let us know what sort of money we are looking at.
  36. jcb
    4,132
    13
    will do.
    Am I correct in thinking that S4 and A4 have different front struts?
  37. docurley
    4,071
    86
    Every thing just bolts up the same the drive shafts have a different drive shaft bolt patten for the gear box so that needs to be swaped out then replace the springs as they will jack the car up but the shocks will be like upgrading when fitted with uprated springs.
  38. jcb
    4,132
    13
    no I meant the caliper lugs on the A4 and S4 struts
  39. docurley
    4,071
    86
    The S4/RS4 use a larger bolt to mount them to the strut.
  40. jcb
    4,132
    13
    Lined my 4 pots and RS4 calipers up with the strut I have (pretty sure it is an S4 strut).
    this is what lies ahead
    Flat, 4 bolt flange required for brembos
    RS4's line up perfectly, carrier must be bigger but bolt holes are the same.
    Getting an A4 strut on Friday
    should know what prices are by the end of week
