New Discs n Pads -ABS Light on!!! HELP!!!!
Big T Feb 20, 2009
  1. Big T
    Big T New Member
    Hi,
    I have replaced the discs and pads on my A4 1.8T but now the ABS light has come on!!!! I have only replaced the drivers side front and rear and the passenger front due to ending up in casualty trying to undo the rear passenger side caliper bolts! Could the ABS light be on because i have only replaced 3 of the brakes??? Im sure i didnt damage any of the sensor wires when i was working on it. Do you have to reset the ECU after replacing discs and pads?? Im very confused! Any advice would be very welcome!!!!!!!!!!:sos:
    Regards,
    Anthony.
  2. Big T
    Big T New Member
    Anyone!!!!!!!!!!!!??????????????:think::sos:
  3. yendall24
    yendall24 Member
    571
    9
    hi mate it is possible you have got some sort of **** on one of the abs sensors this happened to me once my light came on and every time you pressed the brake even slightly the abs activated give the sensor head a wipe with a clean cloth sprayed with some wd40 thats all i did and it solved it
