New discs and pads all round
audi-cdo Mar 20, 2013
  1. audi-cdo
    audi-cdo New Member
    help , new discs and pads all round , now there a knocking sound front drivers side wheel it stops when I applied pressure on the brakes ?????????
    anybody know what it could be all quality parts used as well I have jack up both wheels spinning freely could it be the spring clip on the caliper ????
  2. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Sounds as if something isn't quite fitted right. I'd have wheels off and give it a good checking over and remove and refit if necessary.
    Az
  3. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    3,988
    756
    I had this with some aftermarket pads, the only way I found to fix was to fit some genuine pads, and it stopped.
  4. hades-
    9,482
    646
    iv had it a few times see witch pad is moveing
    i had to have a small shim put in
  5. wyliss
    wyliss Member
    286
    I've had a small rattle sometimes going over obstacles and seeing as I have MTEC discs installed I'm putting it down to them coming without the retaining screw hole. Wheel botls are tight too and this little rattle has only happened since new discs and pads have been installed.
    I've since emailed MTEC and all discs now should come with said hole pre drilled.
  6. Steve220
    Steve220 Member
    234
    15
    I've got a rotational thud through my brakes when i brake, getting louder. Replacing the rears this weekend for new discs and green stuff pads, and my new larger front brakes and red stuff pads will arrive soon :) Hopefully that'll sort it.
  7. gas-man
    gas-man Member
    215
    just got off the phone with mtec ordered drilled and groved disc and pads all round
    had them overnighted so will check if the retaining hole is drilled in the morning
    if they have no retaining hole drilled should i send them back?
    o/p is your brake set up mtec or did you go another route?
  8. wyliss
    wyliss Member
    286
    My discs are MTEC, pads are Mintex.
    Call and tell them you they must have the retaining hole.
  9. Steve220
    Steve220 Member
    234
    15
    I've never used the retaining screw in brake disks. The wheel does a good enough job ;)
    On another note, how would a hole cause a rattle? It maybe something during the installation. Too many variables.
  10. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,462
    3,027
    I have MTEC discs and Mintex pads; no retaining hole, no rattle.
    Steve220 likes this.
  11. B5NUT
    3,988
    756
    You don't need the retaining hole or screw, it just there to make things easy when changing the wheel or pads.
  12. Molnboman
    Molnboman Well-Known Member
    1,338
    194
    +1 on the mintex pads and discs. No problems with them.
    A
  13. audi-cdo
    audi-cdo New Member
    All sorted now had the wheel off caliper stripped down reassembled new brake fitting spring no sound come from Osf wheel now happy as larry now
  14. jdp1962
    8,462
    3,027
  15. wyliss
    wyliss Member
    286
    Possibly found what the rattle was, the undertray !!! It's snowing quite badly here and the weight must have added to the problem. It's the back part of the tray which is now dragging along the floor!
