New dipstick tube plastic - which does it attach to?
wysiwyg Oct 29, 2012
  1. wysiwyg
    wysiwyg Member
    Should it be permanently attached to the dipstick or to the tube?
    Mines a really tight fit on the stick so stays on the stick, pushes onto the tube and comes off with the stick, worried its not on right and want to make sure my dipstick readings are correct.
  2. jamie226bhp
    jamie226bhp Member
    468
    It stays a attached to the engine so the dipstick pulls out, but r prone to breaking due to becoming brittle only about £7 from eBay or dealers
  3. wysiwyg
    wysiwyg Member
    This is a replacement, cant get it to push onto the tube and its mega tight on the stick so sticks to that
  4. NineNails
    NineNails Proud sponsor of the snack food industry
    593
    Genuine or pattern part? Sure you got the right one, does it look like the one that came off?
  5. jamie226bhp
    jamie226bhp Member
    468
    It clips onto a tube lower down that the dipstick goes thought and onto two metal prongs at the top, mine needed a bit of fiddling as the prongs weren't quite in the right place
  6. aragorn
    18,438
    845
    facelifts have the metal prong arrangement.
    PFL just have a plastic bit that pushes onto the metal tube.
    Either way, it should stay attached to the metal tube.
  7. wysiwyg
    wysiwyg Member
    Mines a 99 FL, the old one crumbled into many pieces, cant see two metal prongs?
    I ordered AUDI 80/100/A4/A6 DIPSTICK GUIDE TUBE - 053103663 NEW ! | eBay
  8. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,162
    1,123
    That's a pre-facelift dipstick tube.
    Same one as I fitted to mine the other month.
    Its a right ***** to push on.
    you need to push really really hard and it will eventually give in and pop on.
    But if yours is a facelift, I don't think that's the right one.
  9. wysiwyg
    wysiwyg Member
    Just double checked, mines a tube (obv) with a lip about 13mm down it, thats it.
  10. jamie226bhp
    jamie226bhp Member
    468
    Mine was the same as this eBay item number 180896179827
  11. aragorn
    18,438
    845
  12. wysiwyg
    wysiwyg Member
    Just looked, cant see a bracket on the side of the manifold, and it looks like if the tube were as long as the one above it would foul the bonnet.
  13. aragorn
    18,438
    845
    early facelift with analog clock on the dash then?
  14. wysiwyg
    wysiwyg Member
    Yupp!
