New Custom Exhaust (3.0tdi)
Joe_Murphy21187 Nov 1, 2012
  1. Joe_Murphy21187
    Joe_Murphy21187 Tiptronic
    1,021
    67
    Finally got my exhaust fabricated and thought I would post a few pics. 316 stainless steel construction (apart from the tips which are 304 because they had to be bought). Really pleased with the results! Only downside is the speed at which the tips become blackened! Video doesn't do it justice...
    4" Slashed tips (pardon the cable ties, before the hangers were on)
    Decided to have the tips removable so they could easily be changed if necessary later
    Tricky bit to go round the quattro...
    Video: Audi A4 Cab :: 00008.mp4 video by jjmurphy21187 - Photobucket
  2. ANDYTQ
    ANDYTQ Well-Known Member
    1,177
    101
    Nice jj but will it pass the noise test at combe!
  3. Joe_Murphy21187
    1,021
    67
    Ha, that remains to be seen. But when it's not under load it isn't too loud (not that I have a decibel meter)
  4. astradti16v
    astradti16v Member
    54
    Very nice!, what sort of price would he charge for something the like that?
  5. Joe_Murphy21187
    1,021
    67
    Would've been £750 but the extra flanges for the tips was another £80. Not a cheap option but he can fabricate more or less anything you want and the craftsmanship is 2nd to none
  6. solaris
    solaris Member
    415
    17
    Now that looks like a quality bit of work. Where was that exhaust made?
  7. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Would you mind saying what the setup is in full, for example regarding the catalyst, DPF, secondary cat, silencers etc. I'm looking to get something to improve my exhaust note on mine and unleash the growl (2k rpm +) of the V6 but don't want something too loud as I'm on the motorway everyday and have had bad experiences with boomy exhaust systems.
  8. Joe_Murphy21187
    1,021
    67
    It was made by an independant in Nottingham, 'Wright Bro's Autos' and the guy's name is Dale. Doesn't have a website unfortunately but he came recommended to me and has done a few other audi exhausts.
    He sent me a few pics of others he's done, A6, RS6 and Carl's A4, which I can forward if anyone's interested: drop me a PM
    Setup is as follows: 1st CAT & downpipe is standard, from the downpipe back has all been replaced. Already had the DPF gutted/mapped out so no additional mapping was needed for the new exhaust. Downpipe goes into a straight through silencer (maybe 14" long?), then the pipe splits just before the quattro box and goes round the support struts/ARB etc, then two 4" tips on the end (no backboxes).
    I was after exactly the same thing as you MaJiK, but honestly there is a bit of drone which unfortunately falls just at cruising speed (1700-2000rpm). Now I've been looking into ways to counter this and aside from coating the floor of the car in sound deadening material, I found the concept of adding a 'Side-Branch Resonator' which can be used to eliminate specific resonant freqnencies. Sounds like a good idea and it's what companies like Miltek use inside their backboxes to give a 'tuned' system:
    According to my calculations (lab coat on at this point), for a 6 cyl engine with a resonante freq of 'X', the pipe length should be 'Y':
    RPM = 1700 L = 1.009m
    RPM = 1800 L = 0.953m
    RPM = 1900 L = 0.903m
    RPM = 2000 L = 0.858m
    RPM = 2100 L = 0.817m
    RPM = 2200 L = 0.780m
    So ideally you'd make the pipe length adjustable to change the frequency response, as the res freq changes which exhaust gas temps (hence why the sound different on start-up and after a run) and it's not an exact science. But if the side res runs parallel to the main exhaust it HAS to be a mandrel bend, otherwise it messes with the pressure waves and doesn't work correctly...
    Found this on a US forum for Corvettes and Trucks, a lot of those guys swear by it. Having said that those guys have V8s which require a shorter pipe length to get the same res freq...
    Jespy likes this.
  9. ANDYTQ
    1,177
    101
    Ive seen a exhaust on a a4 with one of those fitted on a US site might have been on audizine
  10. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Brilliant response thanks for that. I may just do the same setup as you have but have back boxes in place to counter the drone at cruising speeds. My only concern as I've probably mentioned many of times is the increase in smoke after the DPF removal.
  11. Joe_Murphy21187
    1,021
    67
    Any idea if it was effective at getting rid of the drone at crusing speed?? Going to enquire about cost of adding this later...
    Might be worth considering the Miltek... if you can get a good deal...
    PS: You could always use the 'Thanks' button :yahoo:
  12. Joe_Murphy21187
    1,021
    67
    What I also meant to say in that post :keule: was that I've never had excessive black smoke after removing the DPF. It can depend on your map and if it's done properly (so I've read), but I've never seen a cloud of black left in my wake in the rear-view... slight hazyness at night through headlights, but that's normal...
    If you want to swing by Nottingham you're welcome to have a listen before shelling out £xxx!
  13. Chr1sch
    Chr1sch Member
    89
    Sounds lovely!
  14. Molnboman
    Molnboman Well-Known Member
    1,338
    193
    Lovely bit of welding that.....classy....can we get a listen to them on YT?
  15. fishyfish
    fishyfish Member
    126
    39
    I agree, those welds are just spot on... makes the workmanship on the Milltek system I have (gets fitted on Monday! woo!) look pretty average, I can tell you.
  16. Joe_Murphy21187
    1,021
    67
    Cheers guys :arco:
    I'll try to get to grips with youtube and post a link... does the photobucket vid not work??
  17. Joe_Murphy21187
    1,021
    67
  18. hapsdoggen
    hapsdoggen New Member
    hi i would like to open this thread and get some feedback if possible.
    i have and audi A6 3.0 TDI from 2008 with de-cat and de-dpf and alot off drone about 2200 rpm 2600 rpm in my car but and awesome sound on the outside.
    i saw your thread and would like to now if this worked for you and the lenght of the side brnach resonater is that from were the mandrel bend starts or ends.?
    what size thit you end up with and were was your drone in rpm.?
    thanks in advance
  19. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,177
    2,211
    It's not to difficult to do a side branch resonator like a trombone slide so the length is adjustable that way you can tweak it. They do work really well to get rid of drone.
    hapsdoggen likes this.
