New Condenser?
landopanda May 18, 2010
  1. landopanda
    landopanda Member
    143
    Hi, the air con on my car doesn't work, hasn't for ages, I think the condenser has broken because the switch doesn't kick in when you turn it on. (correct me if I'm wrong) Anyway... seen a condenser on fleabay for £60 would this make it work again??
    Thanks for any replies
  2. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    65
    Not sure why you've gone straight for the condensor. The condensor is just a cooling matrix and any problems with it would pretty much be it leaking, a blockage or the fan not working.
    You should check the fuses before doing anything mate.
  3. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,797
    sometimes the air con drier can crack and leak, have you had your system re gassed ?
  4. landopanda
    landopanda Member
    143
    Yes I have since realised that its probably not that at all. Maybe the compressor? As i cant hear the switch kicking in i don't think. I've not had it gassed as i thought the econ light stayed on if it needed gassing?? Should i have it gassed first to make sure?
  5. Turkster
    2,797
    get it gassed:arco:
