New car - VAG COM Scan Results
elrao Apr 12, 2013
  1. elrao
    elrao Member
    378
    Picked the car up last night, thought I'd run a full scan before any tinkering (would have taken my laptop and cable with me to the dealer if I'd known before 4.34pm that it was going to be ready to pick up. Results are below, removed for controllers with no error codes. Rather more errors than expected for a car just picked up from the dealer (Fontain).
    01-Engine -- Status: Sporadic communication error 1000
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: Malfunction 0010
    37-Navigation -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    55-Xenon Range -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine (CDL) Labels: 06F-907-115-CDL.clb
    Part No SW: 8P0 907 115 AB HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0010
    Revision: 5BH16--- Serial number: AUX7Z0HNFN30PD
    Coding: 0103000C1C0F0060
    Shop #: WSC 00191 264 15243
    VCID: 72EF82116DAC5988278
    No fault code found.
    Readiness: 0000 0001
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 012 G HW: 02E 927 770 AM
    Component: GSG DSG AG6 512 1974
    Revision: 05651213 Serial number: 00001302122300
    Coding: 0000020
    Shop #: WSC 01089 210 97503
    VCID: 1423E4893778F7B8954
    2 Faults Found:
    18258 - Powertrain Data Bus
    P1850 - 000 - Missing Message from ECU - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Reset counter: 39
    Mileage: 105584 km
    Time Indication: 0
    Date: 2013.04.11
    Time: 11:09:19
    01196 - Engine-Transmission Data Bus
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 0
    Reset counter: 39
    Mileage: 105584 km
    Time Indication: 0
    Date: 2013.04.11
    Time: 11:09:20
    Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
    Component: ESP MK60EC1 H35 0106
    Revision: 00H35001
    Coding: 16428012092900FF681301E4901D0081B900
    Shop #: WSC 06314 000 00000
    VCID: 75E5B90DDCC24EB002A
    1 Fault Found:
    01314 - Engine Control Module
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 110
    Mileage: 105584 km
    Time Indication: 0
    Date: 2013.04.11
    Time: 11:09:19
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
    Component: Bordnetz-SG H54 2801
    Revision: 00H54000 Serial number: 00000009087282
    Coding: 118E0F81B0141380EF00000A0000000000084E0564060403642000000000
    Shop #: WSC 06314 000 08192
    VCID: 489B00F93BB08358A9C
    Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H10 0040
    Coding: 00056595
    Shop #: WSC 06314
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 110
    Mileage: 105584 km
    Time Indication: 0
    Date: 2013.04.11
    Time: 11:09:00
    Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
    Part No SW: 1K0 907 530 S HW: 1K0 907 951
    Component: J533__Gateway H16 0210
    Revision: H16 Serial number: 3400K08B0502B3
    Coding: EDA37F06400602000103
    Shop #: WSC 00588 210 88196
    VCID: 37797305464EFCA0D06
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 110
    Mileage: 105584 km
    Time Indication: 0
    Date: 2013.04.11
    Time: 11:09:19
    Address 22: AWD Labels: Redir Fail!
    Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
    Component: Haldex 4Motion 3016
    Coding: 0000005
    Shop #: WSC 00000 000 00000
    VCID: 438117D50296A0007CE
    1 Fault Found:
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 57
    Reset counter: 48
    Mileage: 3618101 km
    Time Indication: 4
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
    Component: RNS-E PU EU H05 0200
    Revision: 0000011S Serial number: AUZBZ7KD201025
    Coding: 0205755
    Shop #: WSC 00141 211 79330
    VCID: 34634409573817B8F54
    4 Faults Found:
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 71
    Mileage: 105702 km
    Time Indication: 0
    Date: 2013.04.12
    Time: 16:00:40
    00878 - Connection to Speaker Front Left
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 71
    Mileage: 105702 km
    Time Indication: 0
    Date: 2013.04.12
    Time: 16:00:30
    00879 - Connection to Speaker Front Right
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 71
    Mileage: 105702 km
    Time Indication: 0
    Date: 2013.04.12
    Time: 16:00:30
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 71
    Mileage: 105702 km
    Time Indication: 0
    Date: 2013.04.12
    Time: 16:00:19
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 C
    Component: EPS_ZFLS Kl. 234 2301
    Revision: 00H15000
    Shop #: WSC 02069 000 90108
    VCID: 2A5F5A7185FC51485F8
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 120
    Mileage: 105584 km
    Time Indication: 0
    Date: 2013.04.11
    Time: 11:27:01
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 J
    Component: Dynamische LWR H01 0020
    Revision: 00000001 Serial number:
    Coding: 0000013
    VCID: 418D1DDD188AB2106E2
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 0
    Reset counter: 40
    Mileage: 105592 km
    Time Indication: 0
    Date: 2013.04.11
    Time: 11:09:19
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0205755
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 71
    Mileage: 105702 km
    Time Indication: 0
    Date: 2013.04.12
    Time: 16:00:40
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 71
    Mileage: 105702 km
    Time Indication: 0
    Date: 2013.04.12
    Time: 16:00:30
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 71
    Mileage: 105702 km
    Time Indication: 0
    Date: 2013.04.12
    Time: 16:00:30
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 71
    Mileage: 105702 km
    Time Indication: 0
    Date: 2013.04.12
    Time: 16:00:19
    End ---------------------------------------------------------------------
  2. elrao
    elrao Member
    378
    Car had the mechatonric unit replaced yesterday, which may have caused some of the codes, but even after clearing and re-scanning I get a load of 'malfunctions', but not many fault codes in the module
    Readiness: 0110 0101
    Coding: 0000020
    Revision: 00H35001
    Coding: 00056595
    Shop #: WSC 06314
    Coding: 0000005
    Coding: 0205755
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 71
    Mileage: 105702 km
    Time Indication: 0
    Date: 2013.04.12
    Time: 16:06:50
    Revision: 00H15000
    Coding: 0000013
    Coding: 0205755
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 71
    Mileage: 105702 km
    Time Indication: 0
    Date: 2013.04.12
    Time: 16:07:30
  3. Ads
    Ads License to drive
    8,230
    607
    All codes have been generated at one of two times....... 11/04/13 at approx 11:00, and today at around 16:00.... and mention either no signal or open circuit etc.
    Battery problem?? Dodgy VCDS cable?? ECU throwing a tantrum??
    Have you tried clearing the faults to see if they return? Save them first though.
  4. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,662
    116
    Seems okay to me if the mechatronic unit has been replaced that would explain the Auto Trans faults and also the ECU has been out at some point... maybe a remap?
    You also have a retrofitted sat nav which hasn't been coded properly.
  5. elrao
    elrao Member
    378
    Thanks guys - think they just forgot to clear the codes when they finished the gearbox and remap. Am I correct to think that if at the high level where the controller reports 'Malfunction 0010' , but there is no underlying fault code that this is just the car 'remembering' the fault? Took it for a quick spin down the road and re-scanned - all faults cleared apart from the Nav/Radio (phew!). I thought the satnav was factory fit, however from another thread I found out it might be the Mk2 version which could mean it was a retrofit upgrade (car is a Dec 2008, facelift). Coding is 0205755
  6. elrao
    elrao Member
    378
    Based on my coding of 0205755 it looks correct, car has BOSE, Bluetooth Phone, AMI, MFSW. Although I can’t see an option for BOSE or AMI?
    02xxxxx: Model
    [*]2 = Audi A3 (8P)
    0x0xxxx: Treble Speaker Monitoring inactive
    0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet)
    0xx5xxx: Sound Characteristic
    5 = Audi A3 (8P) - or should this be 9 for 'Sound System' as I have the BOSE?
    0xxx7xx: Telephone/Telematic
    7 = Base Plate diagnostic capable with Comfort Control
    0xxxx5x: Equipment I
    5 = Analog Input (AUX) installed
    0xxxxx5: Equipment II
    5 = Multi-Function Steering Wheel installed
  7. vsantos69
    vsantos69 Member
    40
    100% sure that this is a MK2 radio (193) but it doesn´t came from factory with car, was after retrofitted (i think that the radio is from late 2010 or 2011)...
    You can have same coding in the car and don't have the hardware ...
    You say, in another post, that you have rear and front parking sensors but the modulo doesn't appear on the log you posted, to put the OPS working you need factory parking sensors installed (they can be retrofitted, i have done it)..
  8. elrao
    elrao Member
    378
    I only posted the logs for modules with errors!
    Understand I need to change 0x0xxxxx to 0x2xxxxx to enable OPC
    Should I change 0xx5xxx to 9 for 'Sound System' as I have the BOSE?
  9. vsantos69
    vsantos69 Member
    40
    About the bose system i can't help you...
  10. PaulRS3
    PaulRS3 Well-Known Member
    1,209
    141
    If it helps to confirm, my coding (MY11 RNSE MK2 193 G) Bose, AMI, MFSW, Bluetooth, is 0209725
    Initially it was coded to look for a cd changer ( not fitted) so I had to take -2 off the last digit. ( Originaly was 0209727)
    I coded it under radio, and it automatically updated Navigation coding to the same.
  11. elrao
    elrao Member
    378
    Thanks. Going to check the wiring was modified when retrofitting the rns-e and update from 5 to 9.
