jin2
Hi all, I have traded in my previous Audi for another one recently.
The car drives great, but i scanned it anyway, and found these code.
The only one i don't know about is the 'Cent Electric' one, what does it do ? and where is it ?
Any help would be appreciated, thanks.
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 DT HW: 028 101 189 2
Component: R4 2,0L EDC 0000AG 5878
Revision: 12345678 Serial number: AUX7Z0D6FN70ID
Coding: 0000078
Shop #: WSC 06435 000 00000
VCID: 78F4EABE34895DDC
2 Faults Found
17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
P0673 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 168.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 11000100
Temperature: 5.4°C
Bin. Bits: 00110000
17058 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
P0674 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 168.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 11000100
Temperature: 5.4°C
Bin. Bits: 00110000
Readiness: 0 0 0 0 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 E HW: 8P0 820 043 E
Component: KlimavollautomatH12 0150
Revision: 021214 Serial number: 8P0820043E
Shop #: WSC 00000 000 00000
VCID: 2E580CE6864D536C
1 Fault Found
00710 - Defroster Flap Positioning Motor (V107)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 180
Mileage: 179645 km
Time Indication: 0
Date: 2011.01.26
Time: 11:44:27
Freeze Frame:
Voltage: 12.20 V
Temperature: 16.5°C
(no units): 27.0
(no units): 229.0
Temperature: 6.0°C
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H30 0501
Revision: 00030000 Serial number: 00000000909646
Coding: 0588CF00A2141000000000000000000000
VCID: 3B7E35B2453FB6C4
Part No: 8P2 955 119 C
Component: Wischer WWS Audi350 0180
Coding: 14352400
Shop #: WSC 00000
1 Fault Found
02071 - Local Databus
004 - No Signal/Communication - Intermittent
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 E
Component: Tuersteuerger. H10 0030
Coding: 0000120
VCID: 3E783CA6562DA3EC
2 Faults Found
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
00121 - Outside Warning Light/Door exit Light Passenger Side
012 - Electrical Fault in Circuit - Intermittent
Coding: 0000078
2 Faults Found
P0673 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 168.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 11000100
Temperature: 5.4°C
Bin. Bits: 00110000
P0674 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 168.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 11000100
Temperature: 5.4°C
Bin. Bits: 00110000
1 Fault Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 180
Mileage: 179645 km
Time Indication: 0
Date: 2011.01.26
Time: 11:44:27
Freeze Frame:
Voltage: 12.20 V
Temperature: 16.5°C
(no units): 27.0
(no units): 229.0
Temperature: 6.0°C
Coding: 14352400
Shop #: WSC 00000
1 Fault Found
Coding: 0000120
2 Faults Found
