NeilMc1983
- Joined
- Aug 1, 2015
- Messages
- 19
- Reaction score
- 13
- Points
- 3
Hi,
As my brake disc back plates (splash guards) are badly corroded and a real eye sore on my 2004 A3 2.0 FSI Sport 3dr, i've decided to purchas 4 new ones and i'm now in the process of painting them and installing them. i thought i'd post some pics and mini guide in case anyone wants to do the same. i didn't want to leave them standard black as this just highlights how small the brake discs are, painting them metallic gives the effect the discs are bigger and fills up the space in the alloys more. plus adding extra layers of primer and paint add extra protection to the metal guards as they're prone to rusting and corroding really quickly.
BEFORE
ETCH PRIMED AND HALF PAINTED
DRYING
INSTALLED
FINISHED
Part Numbers:
O/S/F: 1K0615312F (£11.08 each from Audi Main Dealer, Skoda dealers are cheaper)
N/S/F: 1K0615311F
N/S/R: 1K0615611AB (£21.30 each from Audi Main Dealer, Skoda dealers are cheaper)
O/S/R: 1K0615612AB
these parts are used in loads other Audi's/VW's/Skoda's/Seat's etc.. so its worth worth shopping around if you don't have a trade account with TPS.
I've only installed the off side rear (rear right) so far. Here's a mini step by step guide how to remove the old guard from the rear which is 99% the same as guides for removing your wheel bearing...
GUIDE FOR THE REARS...
1) Remove your wheel (five 17mm wheel nuts)
2) Pull off your brake calliper and cable tie it out of the way. (use a 15mm spanner to hold the part of the calliper where the bolts screw in as these just spin as you try removing the bolts, then use a 13mm spanner/socket to remove the bolts from the calliper)
3) Remove the little bolt which holds the brake disc to the wheel bearing/hub (T30 Torx head)
4) Slide/manoeuvre the disc out from the wheel bearing and calliper bracket (if you can't remove the disc by sliding/manoeuvring out, leave it in and move on to step 5 then remove the disc)
5) Remove the calliper bracket. ( this is held in with big 2 bolts, you'll need a M14 Spline bit to remove them, they're not easy to remove as there's hardly any space at the back and if they're badly corroded like mine, you'll need a breaker bar and extension bar to crack them off)
6) Remove the wheel bearing/hub. (this is held in by a huge bolt, which is hidden by a metal cap. using a screwdriver and hammer, tap around the cap to pop it off, then undo and remove the big bolt using a M18 Spline bit, it'll take some effort first time, i had to use a breaker bar and a scaffolding pole over it to get extra leverage and torque to crack it. once the bolt is out, the wheel bearing will slide off by pulling it and giving it a tiny tap on the back with a hammer)
7) Remove the old backing plate/splash guard. (they are held in with 3 little T30 Torx bolts)
8) Install your new backing plate/splash guard then put everything back together by following the instructions in reverse. (before putting everything back together, now would be a good time to give everything a good clean, use a wire brush to remove rust. inspect your discs and pads, maybe paint your calliper, inspect your wheel bearing and add some grease to the ball bearings etc... just give everything a mini service)
DONE.
When i get round to doing the fronts, i'll add another guide, maybe it could be helpful to someone. sorry there wasn't more helpful pics in the guide, i didn't think to take more pics as i was going along as i was rushing to get home and watch the football
BEFORE
DRYING
INSTALLED
FINISHED
Part Numbers:
N/S/F: 1K0615311F
O/S/R: 1K0615612AB
DONE.
