New BOV/Div to replace bosch units
powerls Jun 20, 2004
  1. powerls
    powerls New Member
    Just thought some of you guys might be interested in the new Turbosmart Kompact series I saw. It is a direct replacement for your bosch diverter and allows you to vent to the atmosphere and your ecu. It utilizes a 60/40 split and is fully adjustable by hand. Best part is that it will fit perfectly under your valve cover(S4) or in your cramped engine bay(A4). I think it is pretty cool. [​IMG]
  2. Danielson
    Danielson Member
    704
    has anyone fitted one of these to their 18t, how good are they? would like to hear that woosh, but dont wana screw up the readings to the ecu? are they any good
  3. dann959
    dann959 Member
    91
    wjere can you get these and how much do they run?
  4. jetspeed
    jetspeed New Member
    27
    I have the GFB Hybrid which looks almost identical to that BOV and does the same, doesn't screw up your ECU at all so for those of you who are worried about that, you don't have to worry, it won't mess anything up. I am curious as to what it sounds like though....
  5. powerls
    powerls New Member
    I think that the GFB needs to be adjusted using washers. The Turbosmart unit is fully adjustable by hand. Which is nice, considering how much of a pain in the ass to get to the BOV/div
  6. dann959
    dann959 Member
    91
    yeah but the gfb seems to be a hell of a lot cheaper
  7. dann959
    dann959 Member
    91
    is the turbosmart unit loud in between shifts?
  8. powerls
    powerls New Member
    well that will depend on how much boost you are running. I'll just say that it isn't extremely loud, but it will get some attention.
  9. leespears1
    leespears1 Member
    261
    in my opinion - it will sound like an rs escort or a remualt 19! Stay with aftermarket valves like forges closed loop.im selling 2 in the marketplace.
  10. duane
    duane Member
    142
    Will forge or other aftermarket DV's fit under the bi turbo cover or do you have to completely remove it? Also can anyone send me detail's and/or pic's on how to fit them. Any help would be appreciated, thank's.
